headunit, *also new member
#22
on
1 Post
According to Coastal if the MyGig came out of or was intended for any of these vehicles it is a low-speed unit.
LOW SPEED FACTORY
MYGIG RADIOS USED
2007 – 2008
CHRYSLER SEBRING
2007 – 2008
DODGE AVENGER
2008
CHRYSLER 300 AND 300C
2008
DODGE DURANGO
2008
CHRYSLER ASPEN
2008
DODGE CHARGER
2008
DODGE DAKOTA
2008
JEEP GRAND CHEROKEE
2008
JEEP COMMANDER
#23
Digging up an old post, AltAir, good info!
I like your mygig, 2 questions;
1) how much was the harness from lockpick? $269?
2) when you cut out the bezel to fit, does the unit cover the cut edge, or does it butt up to the unit? any close up pics of the cut and how did you cut it?
OOps, 1 more, do you have the uconnect?
Thanks,
LB
Thanks,
LB
#24
on
1 Post
Thanks,
LB
Thanks,
LB
2.) It butts up to it, I don't have any close-up pictures because it was pretty late when I did it and I was hurrying, let's just say measure twice, cut once is a good recommendation Even so I'm the only one that notices unless I point it out and one of my roommates still couldn't tell. I'm going to clean it up at some point with either fiberglass or bondo so it fits nice and tight then paint my center bezel anyway. I used a dremel with a cut-off wheel to do it, not the easiest thing to cut a straight line with.
As for Uconnect I may add it at some point but right now I don't have it. Mine is the non-navigation radio, with the deal I got I wasn't going to complain and I'd rather have the extra space on the hard drive for storing music instead.
