2005 DAK tire size possibility
Old Nov 27, 2008 | 10:24 AM
newmexicoram's Avatar
newmexicoram
Default 2005 DAK tire size possibility
I have a 2" front end lift on my '05 4x4 Dak. with P265 65R 17 tires. Can I have P265 70R 17 tires mounted without any rubbing on hard turns? Tires shops are telling me yes and no. I do quite a bit of off road stuff, hunting and metal detecting. It seems all the tires patterns I like come only in the 70's size. I'm looking for something similiar to the BFG M/T's . I don't worry about wear because I don't drive my truck that much, other than in the dirt. Thanks
Old Nov 27, 2008 | 12:54 PM
turbot_bird's Avatar
turbot_bird
Almost fully articulated on the rear and I do rub on the front with no lift
275/55R20
measures to be a 31"
Old Dec 4, 2008 | 12:27 PM
newmexicoram
How about guys can I put 265 70R 17 on my Dak without rubbing? Gotta make a decision this week.
Old Dec 4, 2008 | 01:14 PM
cramerica's Avatar
cramerica
With the 2" leveling kit and stock rims you should be OK, worse comes to worst you trim a mudguard. I have 265/70 16's and I could easily spare another half inch of radius (i.e. 17" rims).
Old Dec 4, 2008 | 02:54 PM
Frenchy's Avatar
Frenchy
I lowered the rear end on my truck and im running 267 70 16s on my truck, and no rub... you're looking at an inch taller total, so you may rub...
Old Dec 4, 2008 | 03:14 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Heres a tire calculator where you can compare sizes... http://www.1010tires.com/tiresizecalculator.asp
Old Dec 4, 2008 | 04:11 PM
cramerica's Avatar
cramerica
He's got his front raised, not the rear lowered. I think he'll be fine.
Old Dec 5, 2008 | 11:02 AM
newmexicoram
Thanks guys. I'm going for it.
Old Dec 5, 2008 | 04:57 PM
TRX4_2008's Avatar
TRX4_2008
265/70/16 here. Factory tires on the 08.
