Well fellars
Got the truck running again, battery was bone dead... Idk why, buuuuuuuuut on a brighter note, I got my Cortex programmer running...
Set it to 91 Performance tune, and I went out and TRIED to find bare roads to test my 0 - 60, and well I found a sort of bare road, so I put er in 4WD and nailed it, shifted from 1-2 at 6k rpms and from 2-3 at idk what rpms but 58mph, and in 3rd gear I was flyyyyyyyin... I recalibrated my speedo for the slightly larger tires and I ended up pulling off a ... ... ... ... ... 7.6 0 - 60...
I think that's rather impressive...
Nice, that's quick, especially considering that the 6 speed isn't a quick shifter. Is the Cortex strictly for the 4.7L?
Also, 58MPH in 2nd, sounds like you have 3.21's?
Trending Topics
**Sigh** still no love for the 3.7. $430 is too rich for my blood anyway...On a side note, the numbers the Cortex puts up on a 6.7 Cummins are obscene.
And yes, the 6 speed can be quick, but I try to not punish my synchros too often
Can't rev-match on upshifts, especially if you're gettin' after it. At least on '07's, the electronic throttle control holds the RPM up when the clutch is in; the engine will hang for over a second before it starts to drop (yes my foot is off the gas). It takes some getting used to.
Downshifts, for sure. I double-clutch whenever I have the time.
