High Output?
Old 12-26-2008 | 11:10 AM
HammerZ71's Avatar
HammerZ71
Don't know if this will help you identify yours or not, but here is an excellent page on the differences between a standard 4.7 and the 4.7 H.O. Even though it's a Jeep specific site, any 4.7 owner should be able to get some good info from it.
Most components beside the air intake system are internal (cam, crankshaft, rods, pistons, etc.).
Also, of interest, you'll find the Mopar part #s and retail prices on the components necessary to turn a standard into the H.O.
http://www.wjjeeps.com/ho_engine.htm#INTRO
Old 12-26-2008 | 03:45 PM
Baggey22's Avatar
Baggey22
I just checked the VIN and it said that it has the normal 4.7. I guess it's a good thing, this way it limits the size of the camper my dad can get.
Old 12-26-2008 | 04:03 PM
superdak05's Avatar
superdak05
these trucks could pull about any camper you want. stopping the bad boy is gonna be the problem
Old 12-27-2008 | 12:39 AM
Baggey22's Avatar
Baggey22
Now that I know that it's the normal 4.7 what's the "limit" for towing?
If it matters it's a 2007 quad cab.
Old 12-28-2008 | 07:25 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The Magnum 4.7 is only rated at tops 30 hp below the HO, not a big difference in my opinion. As for the towing, right around 7100lb max is possible, but it all depends on trans, gearing, etc
Old 12-28-2008 | 09:03 PM
paul05dak's Avatar
paul05dak
Do you have the towing package? Mine does and even so, i also installed a tranny temp guage. Heat is your worst enemy in towing. I believe my max towing is 6850 for the Dak 4.7 magnum with the towing package. All that was included in the package was hitch, 4 and 7 pin hookups, tranny cooler, larger alt, and heavy duty springs in the back.
Old 12-28-2008 | 11:08 PM
HammerZ71's Avatar
HammerZ71
Yeah, I don't know what it is, but I've driven Grand Cherokees with the standard 4.7 and my Overland with the H.O., I've seen the specs, about 30 HP & 35 TQ, but I swear the "butt dyno" feels like it's at least double that...
Old 12-29-2008 | 03:45 AM
fireman2828's Avatar
fireman2828
I agree. I've driven both trucks, and the H.O. is no comparison. You can deff. feel the diff. in the hp and torq.
If your gonna say not much difference, then you might as well buy the v-6.
Old 12-29-2008 | 04:40 PM
lghtngblt02
haha yeah sorry guys I was making a generalization... I was just stating what I thought about the specs, I do agree though that it probably feels different for sure, never driven the HO, but 30 hp on paper isnt much.
V6s are just dogs jk
Old 12-29-2008 | 05:35 PM
SilverGhost1's Avatar
SilverGhost1
The badge just says Magnum on the back. I'm gonna check the VIN tomorrow, can anyone second what Mikset said about the VIN code?
I can second that. J for the HO, N for the Magnum.
Also, with the HO, you have 8 more spark plugs and it is required/recommended you run 91 Octane vs. 87.
Quick Reply: High Output?
