High Output?
Old Dec 25, 2008 | 01:55 PM
Baggey22's Avatar
Baggey22
Default High Output?
2007 Dakota with the 4.7 V8. How do I tell if it's the "high output" or not? Is there a code in the VIN number that'll tell me?
Thanks
Old Dec 25, 2008 | 03:19 PM
mikset's Avatar
mikset
I believe the 8th digit in the vin will be a J if it's an H.O., an N if it's standard.
Old Dec 25, 2008 | 06:26 PM
MoparPower00's Avatar
MoparPower00
Another way to know is bad the V8 badge on the back of the tailgate. If it's the high output it looks like this.
Old Dec 25, 2008 | 07:19 PM
Baggey22's Avatar
Baggey22
The badge just says Magnum on the back. I'm gonna check the VIN tomorrow, can anyone second what Mikset said about the VIN code?
Old Dec 25, 2008 | 07:29 PM
MoparPower00
I can 2nd the VIN too, cuz when I've looked at certain websites for parts and accesories, it will bring up an extra N or J for me to describe my truck.
If yours only says V8 Magnum though, your should only have the regular 4.7 V8. Don't be afraid to double check the VIN because there badge could of changed from the 2005 to 2007.
Old Dec 25, 2008 | 07:37 PM
superdak05's Avatar
superdak05
look under the hood at the emissions label, it will tell you there also, you can go to www.allpar.com and use there vin decoder to see also.
Old Dec 25, 2008 | 10:12 PM
HammerZ71's Avatar
HammerZ71
Don't know if they do it with the Daks, but my Grand Cherokee Overland says "High Output" on the plastic cover over the throttle body, great big letters...
Old Dec 25, 2008 | 11:31 PM
Baggey22's Avatar
Baggey22
I put a cold air intake on the truck very shortly after my dad got it. So I can't check the plastic cover on the throttle body.
Old Dec 26, 2008 | 12:03 AM
BAdassR/T's Avatar
BAdassR/T
mine says it on the hood bc im special!
Old Dec 26, 2008 | 09:59 AM
superdak05's Avatar
superdak05
walmart special or just special
