cold air intake
Old Dec 30, 2008 | 04:59 PM
biker_ahoy's Avatar
biker_ahoy
Default cold air intake
will a cold air intake improve mpg
Old Dec 30, 2008 | 05:26 PM
SilverGhost1's Avatar
SilverGhost1
not really.
Old Dec 30, 2008 | 05:40 PM
paul05dak's Avatar
paul05dak
depends, on my van (3.8l) I gained 2 MPG, on my truck, I lost MPG cause I just cannot keep my foot out of it. It just sounds so much better!
Old Dec 31, 2008 | 12:05 AM
cramerica's Avatar
cramerica
Thermodynamics. IC Engine pumping losses. Dodgeforum.com search function. Seek these out and you will become wise.
I am trying to be HankL.
Old Jan 1, 2009 | 04:34 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by ericemery
How many times do we have to cover this topic? I am certain the search button would have pulled up at least 3 threads regarding that same question.
By helping the efficiency of the engine, you will in theory create more power. If you are making the same power, at a lower RPM... you in theory will save fuel... Less gas to accomplish the same power load... will you gain a noticeable amount of economy from an intake? I gained maybe a 1/4 mpg from the intake... MAYBE.
If you get an intake, and get on it just to hear it suck in air, you will lose mileage. Most of us did it at first. Some still do I am sure.
If you want more MPGs, search for the hypermiling thread... by changing some of your driving habits, you will save more than an intake could.
Well put
hahaha, yeah, hes too technical, those things are only seen in EXTREME cases For just a shade tree mechanic/power enthusiast, you'll never even see that
Old Jan 1, 2009 | 11:02 PM
fireman2828's Avatar
fireman2828
Another thing people forget to compare is engine size, tranny, gear ratio, driving conditions, etc..... I'm sure my cia would get me a tad better mpg if I would keep my foot out of it. I bought a v-8 truck, not a 4cyl. car....
Old Jan 2, 2009 | 08:25 AM
cramerica's Avatar
cramerica
I got up in the 25 MPG range by changing my driving habits. Do what eric said, search hypermiling. Basically :
1) Run tires ~5# over stock pressure (any higher risks uneven wear)
2) Accelerate *sllooowly*. Make 55 just as you reach the end of highway ramps. If you have a stick, shift at 2000 RPM or less. Light foot is the key.
3) Cruise at 55 MPH. 60 absolute max.
Also, don't expect wonders in winter or hilly country. I got 25 MPG for one tank, but it was 80% expressway driving in flat *** South Carolina. If you have 4WD with an automatic, you won't be able to do as well as a 2WD manual. I actually stopped doing it because it's just not safe sometimes, especially on the interstate.
