Problem with engine, don't know what it could be
Old Jan 3, 2009 | 07:38 PM
  #21
rking92y's Avatar
rking92y
Default "Diagnostic Mode" 05 Dakota
05 Dakota-----
Place key in ignition
click 2 clicks forward (guage lights light up)
click 1 click back (lights off)
click 1 click forward (guage lights on)
When The mileage turns to ----------
That means it is in diagnostic mode. If there are no codes, it will say "DONE" You might have to wait for it. If you see the ----------- then you are right.
Sorry for the confusion, I sometimes forget people do not know how to do this. I am sorry.
Rich.
If you need help with what the codes mean, just reply or E-mail.
supply_daddy71@yahoo.com
Old Jan 3, 2009 | 07:48 PM
  #22
phil74501's Avatar
phil74501
I tried it as you described rking. Still nothing but the odometer reading. Thanks for the help though.
Old Jan 3, 2009 | 08:55 PM
  #23
bgibb68's Avatar
bgibb68
i was wondering about the egr....that's close to what my car was doing before i cleaned it....it just never died....it would almost but then pick back up
Old Jan 3, 2009 | 09:09 PM
  #25
phil74501's Avatar
phil74501
My truck has a little over 52K on it. It started around 50k. Not sure if egrs are supposed to start messing up around then or not.
Old Jan 3, 2009 | 09:15 PM
  #26
bgibb68's Avatar
bgibb68
my car(2.0l 4 banger) started doing it at like 60k-70k intermitently....all it takes is a lil bit of crud and i know engines will throw that poo out....
Old Jan 7, 2009 | 03:43 PM
  #27
phil74501's Avatar
phil74501
I finally got to Autozone this morning and had then check for codes. It had two. P0344, something about a cam sensor. P0420, catalytic converter.
Old Jan 24, 2009 | 01:59 PM
  #28
hendrixx324's Avatar
hendrixx324
Originally Posted by phil74501
I'm driving down the highway with the cruise control on. The check engine light comes on and engine revs down. It would only do that if I got it above 70, not under that. Eventually check engine light goes off and it worked fine. About a week later the check engine light comes on and it starts sputtering if I get it above 2000rpm. Below that it ran fine, but when it got too 2000rpm it acted like you were pressing on the gas and letting off quickly. That stopped after about 15 minutes. It ran fine for about another week. Then last night driving down the highway the check engine light comes on and the engine dies. It restarted again with no problem, and ran fine. Check engine light has gone off. Any ideas what it could be? Sounds like a sensor to me.
i had that problem where it only reved up to 2000 rpms and just sputtered after that and its under warrentee so i took it in an they ended up replacing my engine
Old Jan 24, 2009 | 02:06 PM
  #29
superdak05's Avatar
superdak05
cam sensor is a easy fix, its right in frt of motor behind water pump, as for the cat. they are warrentied for 100000 miles, dodge will replace that for free
Old Jan 25, 2009 | 10:27 AM
  #30
nater474's Avatar
nater474
i have replaced the cam pos sensor three times in 1 month any help email me at nater474@aol.com thanks nathan
