Muffler selection help
Old Jan 14, 2009 | 12:53 PM
stonfootball's Avatar
stonfootball
here you go heres a video of the truck. enjoy
http://www.youtube.com/watch?v=Pbq6BB4LQlQ
Old Jan 14, 2009 | 02:50 PM
SilverGhost1's Avatar
SilverGhost1
I will be getting a new exhaust this spring. On my '07 I only have the the large muffler and the rear resonator. There is no front res. So, my concern is back pressure. Since there is no front res, will there be a enough back pressure with one SiSo or SiDo set-up? Some input would be appreciated. thanks!
Old Jan 14, 2009 | 04:25 PM
stonfootball
yeah you'll be fine with no resonators...i think almost everyone here with an exhaust has taken both resonators out. it will be fine no worries.
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I am running the Single in/Single Out Silver, on my 07 with no problems.The loss of break pressure is so minimal that you can disregard your worries Theres a thread on here where I talk about the differences between single and duals, change of your torque curve and back pressure...
Old Jan 15, 2009 | 08:41 AM
rick4dak's Avatar
rick4dak
After having a Flowmaster Series 50 SI/DO with the tailpipes exiting under the back bumper for 2 years and not liking the resonance in the cab, I switched to a Flowmaster SUV with the tailpipe exiting in the stock position. The resonance is gone, it's quieter but no change in power. I used stock-sized tubing for both systems and an after-market resonator in front of the Flowmasters.
Old Jan 15, 2009 | 08:56 AM
lghtngblt02
Originally Posted by ericemery
2.5 pipe wouldnt cause much of a loss in B.P. anyway. when you go up in pipe size, you run the risk more. Resonators dont really hinder the flow of air much either. not nearly as bad as the cat or muffler.
You are right, they basically cancel sound, by causing it to bounce into the other sound waves, thus quieting it down...
Old Jan 15, 2009 | 01:00 PM
SilverGhost1
thanks for the input. I will more than likely just do a SiSo set up with a Cherry Bomb exiting out the stock location. Or just do what I did on my '06, which was just to replace the big-*** muffler with a Cherry Bomb. I would rather keep the stainless pipes. We'll see how finances are.
