Removing last resonator and changin Y Pipe, How much?
Old Jan 23, 2009 | 11:54 AM
Cuban11182's Avatar
Cuban11182
Default Removing last resonator and changin Y Pipe, How much?
I have a guy here in town that says he will change the Y-Pipe and remove the last resonator for 60-70 bux. Is that worth it?
Old Jan 23, 2009 | 01:09 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Sounds like the upper limit, but a decent deal. I have 140 some in my exhaust which is new aluminized pipe from the y back and a cherry bomb pro muffler.
Old Jan 23, 2009 | 01:23 PM
Altair's Avatar
Altair
Dak attack!
Is he supplying the Y-pipe or are you? Also which Y-pipe would you be putting in?
Old Jan 23, 2009 | 02:39 PM
superdak05's Avatar
superdak05
most likely he will do what i had done. where the y meets cut that off and put a larger coupling on. thats all, you dont need to change out the piping.
Old Jan 23, 2009 | 03:07 PM
newmexicoram's Avatar
newmexicoram
Sounds a little high but, if he does it right and you are pleased then it's worth it.
Old Jan 23, 2009 | 05:30 PM
coondog05's Avatar
coondog05
its worth every penny... its a good hour+ job to do right and you will be shocked at the results as well! a stainless magnaflow is your best bet but there are cheaper metal ones...
Old Jan 23, 2009 | 05:50 PM
Cuban11182's Avatar
Cuban11182
I already have the Cat Back Flowmaster. I believe all he is doing is putting in a Y pipe and removing the resonator. I'm going to look at it on Monday and make sure it is what I want. It will be the same size.
Old Jan 23, 2009 | 07:17 PM
coondog05's Avatar
coondog05
all hes doing.....? its not that simple of a job.... its up over a crossmemember and close to one of the cats... its not easy to get a nice weld all the way around the bigger y pipe! just because a plain jane exhaust job only costs 150 or so, dosent mean what hes doing for you is a little job... if you dont feel its not worth it, take a sawzall like i did and start hackin away.... then bring it to him after your totally frustrated (and bloody) hahaha... just my opinion.....
Old Jan 23, 2009 | 07:20 PM
coondog05's Avatar
coondog05
oh... and the stainless magnaflow is an aftermarket y-pipe that i was referring to! not a muffler....look under your pail and then look at one of these y-pipes and youll see what im talking about
