towing
hi to all i know there is a thread on this somewhere but im in iraq and dont have much time to look so can anyone tell me the max weight that we can pull with our trucks i have a hitch and trailer brake i just cant remeber the weight thanks in advance
Depends on engine, trans and axle. Trucks with the towing package have an extra leaf spring too. My V6 manual with 3.21's is only rated to a bit over 3,000. It could probably pull more, but without a brake controller stopping would be dangerous.
V8's with 3.92's, brakes and tow packages are 7,000+ I believe.
I have an 06 Dak with the 3.7L, manual transmission, and 3.55 gears. I installed the factory hitch and wiring harness and towed my race car for 70 miles with no issues. Combined trailer weight + race car was at 5400lbs. Granted, I do not have a brake controller, so I make sure that in the event of an emergency stop, I have more than enough room. I have also towed a 6100lb combined weight of trailer and car for 60 miles. This was a little tougher...but I stayed in 5th gear most of the time.
Haha nice! The 3.7L will always get the job done, but it might take some time. I've done the math, and IMO, even 4.10's in a V6 manual would make highway driving acceptable, up to about 65.
If I had money to burn, I'd sink it into gears, rear airbags and a full 7 pin brake controlled towing harness. Then all I'd have to do is find something to pull ;D
4.10's would make a 6 speed a blast on the street too.
alright thanks everyone i apppreciate that i do have the V8 with tow package and 3.92 gears i was just makin sure thanks again
Trending Topics
Definately, and I did NOT have the power wire installed when I towed the 6100lb car and trailer.
Honestly, when I towed my race car, I was doing 70mph on the highway just fine. I had no bucking issues (no weight distribution bars) or worryful braking. But then again, thats when I had the 245/70/16s on...so I had a little better final gear ratio to the tires than I do now.
If I could get a set of 3.92s, I would be happy. The only problem is, I have to buy two sets...f$%#...
here is a link to a site very useful for these kind of questions.
http://trailerboats.com/glb/ford/tow...t=&max_tlimit=
Thank you for all you are doing in the sand box. Stay safe!
Damn, you can tow with them things? Really? I always thought them there Daks was kinda like Hyundai Accents with little beds on 'em. I guess they're kinda like little bitty trucks then, huh?
Now before y'all get uppity, I'm just kidding fella's. Bad night in the OT section, just needed to cut up a bit...
