"GASCAP" error.
Old Feb 26, 2009 | 04:43 PM
DodgesForLife24's Avatar
DodgesForLife24
Default "GASCAP" error.
I'm getting it again, only this time I get no check engine light like I was last time. I know that the "gascap" isn't loose, it's tightly on there. Is there something wrong with the seal? I was going to take into the dealer, but am hoping its something simple like all I need is a new gascap.
Old Feb 26, 2009 | 05:01 PM
Cuban11182's Avatar
Cuban11182
you might need to replace the gasket on the cap. pretty sure its an oring
Old Feb 26, 2009 | 05:03 PM
DodgesForLife24
The gasket?
Couldn't I just replace the gascap?
Whichever is easiest...
Thanks.
Old Feb 26, 2009 | 05:44 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you could replace the gascap, not sure which would be easier, but id just go try a new gascap
Old Feb 26, 2009 | 05:48 PM
Cuban11182's Avatar
Cuban11182
It's just an oring. You can replace it if you want, or just replace the gasket which is cheaper. If you want to replace the gasket get either butyl or nitrile so they withstand the gas fumes.
Old Feb 26, 2009 | 06:09 PM
BAdassR/T's Avatar
BAdassR/T
i would just go to the dealer and go find a dakota and take that gascap..
Old Feb 26, 2009 | 08:17 PM
Cuban11182's Avatar
Cuban11182
Just make sure the material is compatable with petroleum products (butyl, nitrile)
Old Feb 27, 2009 | 12:26 AM
DodgesForLife24
Thanks! Yea, I'll go get a gascap probably, seems easiest! If the gascap message keeps popping up, then what could the problem be?
Old Feb 27, 2009 | 12:35 AM
dakolorado's Avatar
dakolorado
start there its the cheapest. The oring is a good start. I know that sometimes there can be a crack in a breather hose to the charcoal canister that can cause this too. Ask me how I know. Sometimes its the system not just the cap that is the culprit. A smoke test is best.
