LED Mirrior Signals
Old Mar 17, 2009 | 01:06 AM
ap0091's Avatar
ap0091
Default LED Mirrior Signals
I want to do something like this
What would be the easiest way to tap the 12v supply into the turning signal line.. Where can this be found?? thanks.
Old Mar 17, 2009 | 01:24 AM
Frenchy's Avatar
Frenchy
in the headlight, grab the wires that come out of the turn signal, and tap into the one that turns hot onlywhen the blinkers are applied... and then into the ground...
Old Mar 17, 2009 | 01:43 AM
ap0091's Avatar
ap0091
Would i just cut it, attatch the 12v line to the cut line, then put it all back together???
Old Mar 17, 2009 | 01:48 AM
Frenchy's Avatar
Frenchy
get these things...
Old Mar 17, 2009 | 02:46 AM
ap0091's Avatar
ap0091
Originally Posted by Frenchy
get these things...
What are they called, and what is the purpose of them??
what it looks like is you put the main signal wire on 1 side, and the 12v to the mirror signal lights on the other side and it connects them??? is that the function?
Old Mar 17, 2009 | 05:40 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The purpose of those little things is they making splicing a snap, literally. You dont have to cut the wire. Just push the plate closed and then snap it shut
Old Mar 17, 2009 | 12:11 PM
ap0091's Avatar
ap0091
I know how to splice, its just like splicing speaker wire right, and ive wired a few lights running on the same line @ my school before.. So i was thinking its jus like that, but the hard part for me is finding that main line for the signals
Old Mar 17, 2009 | 12:51 PM
BAdassR/T's Avatar
BAdassR/T
get these things...
those things suck big monkey *****!
get some crimps and do it the right way....
Old Mar 17, 2009 | 02:36 PM
biker_ahoy's Avatar
biker_ahoy
stick a volt meter into the plug that the bulb slides into and check for a pulsing on the meter, I found that both the running light and blinker both made it pulse (weird right) but the blinker was a stronger pulse
