Shedding Light on power steering issues
Old Mar 24, 2009 | 06:11 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default Shedding Light on power steering issues
Hey. I found out some more about the power steering racks that Dodge uses on its trucks.
I found a great site for car complaints, and there are some dodge dakota steering issues on it for the 05+ model years, but even MORE scary, are the issues of the history of the Dodge Rams as seen below:
http://www.carcomplaints.com/Dodge/R..._failure.shtml
I really hope that this doesnt wind up happening to us. You can see several guys replaced rack after rack after rack, and they just keep sh*tting the bed.
I guess we know it 100% was not the lift kit that caused my issue, it seems to be the quality of the rack. I doubt the part is much different from the ram vs. the dakota.
Old Mar 24, 2009 | 06:40 PM
Cuban11182's Avatar
Cuban11182
I hope you are wrong!
Old Mar 24, 2009 | 11:27 PM
ramos160's Avatar
ramos160
That sucks, I've had to replace my steering pump one time already and it feels like it's starting to act up again. I had it replaced about 5k miles ago. I can't remember how much it cost. I spent $1800 bucks in total, this was for 1 balljoint, steering pump and transmission line and had some other regular maintenance work done. When I took the truck in for the steering issue I found out all those other things were wrong with it. Truck has 46k miles.
Old Mar 25, 2009 | 11:44 AM
importkiller76's Avatar
importkiller76
Just replaced my second return line on the P/S in less than two months, plus both shops said the rack was leaking, and just got that stupid speed sensor issue fixed.....o god what next!
Old Mar 25, 2009 | 11:51 AM
MonkeyWrench4000
Damn.
Old Mar 25, 2009 | 04:00 PM
cramerica's Avatar
cramerica
Dodge has a real issue with light duty truck front ends. Mine is trouble free to date, but I feel it's just a matter of time.
At least I have GEICO mechanical breakdown insurance up to 100,000 miles...
Old Aug 29, 2019 | 06:53 PM
dsereday's Avatar
dsereday
This seems to be the only thread relevant to my situation. I have an 06 Dakota 4x4 that has gone through 7 power steering pumps. I have had the rack and lines replaced, current mechanic is suggesting a ZF pump. I have no clue, the front drivers side is so loud and squeaky its unbearable. Steering is fine when it is cold but after it running I loose power at lower RPMS. I have to gas it to get around a corner. Any help before I light it on fire
Old Aug 29, 2019 | 08:13 PM
Could be the pump, or the rack. If the pump is loud, time to replace it. Spend the money on a GOOD quality pump. NOT cardone..... their quality is abysmal. (I went thru three, and finally just sprung for a better pump. That worked.) If you still have power steering issues, time for a rack.
