subs
Old Mar 25, 2009 | 01:16 PM
BAdassR/T's Avatar
BAdassR/T
Default subs
can we hook up subs to our stock head unit?
just checking to see if i have to change my unit before i go and build/buy stuff...
Old Mar 25, 2009 | 02:07 PM
biker_ahoy's Avatar
biker_ahoy
I would have to say no, unless you tie the subs into the rear speakers but This dosen't have a very good sound, aftermarket head unit will also give you more options depending on the unit. and the sound difference is worth the cost.
Old Mar 25, 2009 | 02:11 PM
BAdassR/T's Avatar
BAdassR/T
oh i know all about aftermarket ones.. im just trying to figure out if i could hook up subs for the time being to the stock crap... ill be getting a mygig eventually but for now i want to be able to use the stocker....
superdak05's Avatar
superdak05
if you run an amp off the factory head unit yes, the factory head unit, does not put out enough umphs to get the sub up to load,
Old Mar 25, 2009 | 02:13 PM
BAdassR/T's Avatar
BAdassR/T
yeah im going to be running a pretty big amp....... so then the answer is yes?
Old Mar 25, 2009 | 03:06 PM
Altair's Avatar
Altair
Dak attack!
Yes you can, it won't sound as good though. If your amp has line level inputs you can tap off the speakers and hook up to that. If not you will need a line out converter to go between the signal from the factory head and the amp's inputs.
Old Mar 25, 2009 | 07:13 PM
ap0091's Avatar
ap0091
Yes, i had a line output convertor for a while with my stock headunit..
I eventually got Aftermarket and have much more control over the sub, so happy about it.
Old Mar 25, 2009 | 08:14 PM
BAdassR/T's Avatar
BAdassR/T
well for now i want to keep it but when i get a good deal on a mygig i want to go that route... but as long as i know i can keep stocker for now im cool with that...
