Rust.
Old Apr 3, 2009 | 05:38 PM
DodgesForLife24's Avatar
DodgesForLife24
Default Rust.
Rust is awesome.
Old Apr 3, 2009 | 06:13 PM
biker_ahoy's Avatar
biker_ahoy
Default Rust
I also have a small chip in the front driver wheel well I need to get it looked at soon here. starting to rust
Old Apr 3, 2009 | 06:37 PM
DodgesForLife24
Old Apr 3, 2009 | 06:55 PM
importkiller76's Avatar
importkiller76
Well I drive gravel everyday so rock chips are just a part of life here....but I hear ya it's a pain in the *** to have to fix chips!
Old Apr 3, 2009 | 08:27 PM
graythang's Avatar
graythang
Welcome to almost non-existent finish. Paint on mostly American cars is VERY VERY thin. They cover it with a thin clear coat and that’s it. The Primer also trash. I have been chasing rusting chips since it hit the road. I whish I could find a way of the perfect repair but its next to impossible.
Old Apr 4, 2009 | 09:58 AM
Racinartist's Avatar
Racinartist
When I had my 05 I had a few 'dings' on the leading and trailing edge of the front and rear doors. They were small, about an 1/8th inch or so, but they started rusting because they went all the way to the metal. How the paint got chipped there I have no idea, but when I asked the dealer about it I was told that kind of "incidental damage" (paint chips, etc) isn't covered under warranty. What a crock. No way should a new vehicle's paint chip off like that, but they basically have us by the *****.
If the chips are small, and you feel like taking the time to color-match by trial and error, you could always dab Rustoleum on the dings. The stuff actually works on light rust.
Old Apr 4, 2009 | 11:15 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Originally Posted by DodgesForLife24
Mine is in my back left, drivers side. I wish it was covered under warranty. I don't know what I'm going to do about it, but even though I can barely see it the fact that it's there bothers me.
Man, if thats the way you feel about chips, your in for a ride. Honestly....it may sounds dumb to some, but I always take a tiny dab of clear auto silicon, and dab it over the chip. works like a charm, but doesnt fix the look. Definately stops the rust 100% though.
Old Apr 4, 2009 | 12:42 PM
DodgesForLife24
Old Apr 4, 2009 | 06:03 PM
object16's Avatar
object16
Use your DREMEL tool!!!
Pretend you are a dentist, and buy a little tool steel grinding ball for your Dremel. grind out the "cavity", mix up a little bit of epoxy glue resin plus hardener to fill the defect, and then put a little dab of paint on top.
