rear axle blocks
Old Apr 6, 2009 | 06:22 PM
Dinger838's Avatar
Dinger838
all set.. total of 25.76 one question...even the 4x4 trucks need rounded u bolts right?in the manual it says some dodge trucks 4wd need square. this looks extremely easy to put on Thanks everyone looking forward to posting pics!
Old Apr 7, 2009 | 09:26 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I am pretty positive that all 2005+ have the round u-bolts in the rear. You can see them, just peek under there, they hold the axle to the leaf spring just behind each tire. When you remove your rear tires, you will see the nuts and the top of the ubolts staring you in the face. If you don't want to do it yourself, its 1 labor hour tops for then whole rear.
Old Apr 7, 2009 | 11:30 AM
Dinger838's Avatar
Dinger838
yep its round i looked thanks
Old Apr 7, 2009 | 01:07 PM
biker_ahoy's Avatar
biker_ahoy
That some good info, also helps me out! Thanks guys.
Old Nov 15, 2011 | 10:22 AM
Mickinator's Avatar
Mickinator
Default Which U-Bolts To Get?
Originally Posted by MonkeyWrench4000
You want 1.5" or 2" lift blocks, that are 2.25" wide, with NO Taper for drive angle correction. These are the most common lift blocks around. Do you have an Advanced Auto Parts store around you?? They sell a steel block kit that I used on my dakota, it works great. They also come with the U-bolts you need which are about 10.5" long, you need ROUNDED end u-bolts, with a 3" inner diameter.
Those U-bolts will work if you have the 8.25 axle, if you have the 9.25 those u-bolts will not work.
I have the 9.25. What should I get for u-bolts?
I'm going to get a 2" lift block to go with my 2" front leveling kit, which is already installed.
Old Nov 15, 2011 | 05:58 PM
Mickinator's Avatar
Mickinator
I picked up these at Advance Auto this afternoon. I crawled under the truck to see if they fit. They seem rather tight to get around the axle. Maybe that's the way that they are supposed to be.
http://www.autozone.com/autozone/acc...er=540310_0_0_
Is this correct or should I get something else?
If I need something else, I'd sure appreciate a link to it.
Old Nov 15, 2011 | 07:28 PM
I want to know to because.....well...i want blocks too...lol..cheapest I can find is like $85 on ebay. seems a bit much for a couple of aluminum blocks and 4 u-bolts...
Old Nov 15, 2011 | 09:19 PM
Mickinator's Avatar
Mickinator
I paid less than $30 for the kit at Advance Auto. I'll take it to my shop on Thursday to see if it's correct.
Old Nov 15, 2011 | 10:42 PM
Eimer123's Avatar
Eimer123
UGH, please do not so this. Aluminum blocks are for lowering, not raising.
Aluminum blocks will compress over time and cause the u-bolts to come loose. I do not think I need to explain what will happen then.
You are gonna need 3-1/2" wide u-bolts for the 9-1/4" rear, and spend the money on cast iron blocks that are the same width of the leaf springs.
Not many local auto stores sell 2-1/4" wide u-bolts. Your best bet is to find a local company that can make you a beefy set.
I bit the bullet and had a local company make up correct size beefy u-bolts for a grand total of $30 bucks.
I then bought Tuff country cast iron 2" tapered lift blocks by 2-1/2" wide, for another $30 on eBay
Old Nov 16, 2011 | 12:35 PM
MonkeyWrench4000
A few tips:
It sounds like you don't have the 8.25 axle,but the larger 9.25.
As far as I know, advance auto sells cast iron blocks as well, not just aluminum.
Those blocks are fine, but the u-bolts and the hardware are junk. See the fine threads and the crummy nuts compared to the stock u-bolt on your truck already? The sheer strength is not so great.
Order from Stengel Brothers. Just google search them, they can ship you real u-bolts.
You can use teh length of the U-bolts you bought as a measurement, but not the width, because they clearly don't fit. You shouldnt have to hammer them on to the axle, they should fit easily.
