rear axle blocks
Old 11-16-2011, 12:49 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
A few guys had good things to say about .Stengel Brothers.
http://www.stengelbros.com/U-boltKits.htm
Here is another site, you need to measure the U-bolt though.
http://www.sdtrucksprings.com/u-bolt...d586335a247f00
Let's get the measurements for future reference.
A= 9/16
B= 3-1/2" (9.25 rear) , ---> Let's get this measurement for the 8.25 rear, (Same maybe??).
C= 7-1/2"Stock measurement, and then you add to it.
. .....Simply add 1 inch for 1" block, add 2 inch for 2" blocks.
  #22
Old 11-16-2011, 08:57 PM
Mickinator's Avatar
Mickinator
Mickinator is offline
I'm surprised that there isn't a posting somewhere on here telling us all what to buy.
if I ever get it figured out, I'll post links to everything.
I need to get it done though because my headlights are shining up too far.
  #23
Old 11-16-2011, 09:37 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
A=9/16
B= Let's get this measurement for both 8.25 rear and 9.25 rear.
C= Lets get the stock measurement for this, and then you add to it.
Here is stock 9-1/4"
A= 1/2"
B= 3-1/2"
C= 7-1/2"
With 2" Block FYI - Tapper goes forward (shorter in front, taller in rear - to keep drive angle that same)
A= 1/2"
B= 3-1/2"
C = 9-1/2"
That is a glow stick hanging from my brake line - could not find my flash light lol
  #24
Old 11-18-2011, 05:23 PM
Mickinator's Avatar
Mickinator
Eimer123 - Where did you get the block?
  #25
Old 11-18-2011, 05:39 PM
Mickinator's Avatar
Mickinator
I'm going to order these.
http://bit.ly/ss6cbP
I'll also be ordering the U-bolts from Stengles.
  #26
Old 11-18-2011, 06:24 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
I bought mine on eBay.
Note, if you buy cast iron ones you will need to cut off the stock stud welded to the top of the axle that goes through the leaf springs. I suggest that you take a c clamp and put the around the leafs to keep them together while you unbolt the old leafs.
Quick Reply: rear axle blocks
