Blown287 05
Thank you, those are GA 4.5s wrapped in Nitto 4220S tires.
Alot of moving around and fabrication went into the blower install. I had a local hydrolic services shop fabricate A/C lines, cruise control module had to be relocated, air temp sensor had to be relocaed, I had to trim my radiator overflow bottle, run new heater hoses, etc.
http://cgi.ebay.com/ebaymotors/TURBO...ht_5207wt_1280
Is this turbo to small for our truck? And what all would need to be done to make it work? It seems that all the parts you guys have mentioned that are missing from the STS setup is included. It comes with the boost controller, oil lines, intercooler, blowoff valve, etc.
Guest
Posts: n/a
