Im guessing this is a brake fluid leak
Old Apr 25, 2009 | 09:58 AM
snipingdude's Avatar
snipingdude
Default Im guessing this is a brake fluid leak
Well actually I know it is...brake fluid levels in the master cylinder keep falling...sigh...braking is sinking to the floor, and im gonna have the dealer check it out...=P, anyone ever have this problem or had it fixed before?
You can see the whole tire is wet since it was being driven around...boy it isn't safe to drive
Old Apr 25, 2009 | 10:47 AM
BAdassR/T's Avatar
BAdassR/T
check for a broken line.. or try and find where its comin from... only idea as of now lol
Old Apr 25, 2009 | 01:12 PM
coondog05's Avatar
coondog05
your wheel cylinder seal is shot...inside of the drum!
Old Apr 26, 2009 | 01:32 PM
dakota_raven's Avatar
dakota_raven
Break line or cylinder that is an easy fix that you can do yourself!! Is you want that is!!! Just make sure that you clean the drum and the break shoes really good with break cleaner!! Don't know if your truck is still under warranty, if it is take it to the dealer and if is not, like i said, "EASY FIX"
Old Apr 26, 2009 | 01:57 PM
Blown287's Avatar
Blown287
I'm a do it yourselfer, lol. If you do it yourself, I would pick up a repair manual. This is the one that I use.
Old Apr 26, 2009 | 07:55 PM
snipingdude
thanks for all the help guys..im gonna try it myself first then =D
Old Apr 27, 2009 | 10:48 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Its a wheel cylinder, or I would bet on it anyways! Not a hard install and they usually arent two expensive, just be careful when removin the line, they can snap and you'll be replacing a portion of the line, GOOD LUCK
