180 therm.
Old May 29, 2009 | 12:56 AM
sullysdetailing's Avatar
sullysdetailing
Default 180 therm.
Where can I find one for the 3.7L
Old May 29, 2009 | 08:30 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Napa?
Old May 29, 2009 | 10:15 AM
lghtngblt02
Id almost bet its the same as the V8s
Old May 29, 2009 | 02:33 PM
superdak05's Avatar
superdak05
napa 530080, $6.00 all you need is to dremel out that small notch that the factorystat has
Old May 29, 2009 | 09:21 PM
Blown287's Avatar
Blown287
Mine is a prestone 330-180. Like SD said, it doesn't have the little ball so you can use a dremel to make a small openng in it.
Old May 29, 2009 | 10:35 PM
sullysdetailing
I was looking for an after market 180 thermastat so the motor will run cooler. Also does the Flex-a-lite fans help alot?
Old May 29, 2009 | 10:46 PM
sullysdetailing
The 180 temp of the flex-a-lite ?
I want to get both
