2005 Dakota Problem
Old Jul 29, 2009 | 11:24 AM
redtexan7's Avatar
redtexan7
Default 2005 Dakota Problem
I have a 2005 Dakota QC 4X4 Laramie AWD.....just turned 50,000 miles but am having a humming noise coming from the front end. It gets louder/softer when I speed up/slow down. Trunk is/has been in great standing (oil always changed, tires rotated and balanced). I just put new tires on her 245/65/R17 (originals 265/65/R17) radials about 5000 miles ago and it has had a humming noise....(might have been there before I changed tires but just didn't pay attention enough) A guy at a tire shop said it sounds like the bearings are going out....Any help??
Old Jul 29, 2009 | 06:55 PM
Blown287's Avatar
Blown287
Check your serpentine belt. If anything is rubbing against it you will get a high pitch noise at higher RPMs and it will slow down at lower RPMs.
Old Jul 29, 2009 | 09:20 PM
redtexan7's Avatar
redtexan7
I went to a tire shop today and they said that my front right bearing/hub is out. (also means that the left is sure to go soon!!) I was told it is a dealer part only and the place said it would be 633+tax to fix both bearings/hubs......this sucks!!
