Under The Hood
Old Aug 1, 2009 | 05:51 PM
Blown287's Avatar
Blown287
Default Under The Hood
During this last month I've gotten alot of questions about just how much is under Impules's hood and difficult it was to fit. So here we go.
Here is an overall shot.
The heart of the project. Here is the Paxton Novi 1000 Supercharger. To the left is the washer bottle I decided not to use. Instead I trimmed by stocker and molded it using a torch. The wire braded line is my oil delivery line that is attached to the block oil sending unit. To the side is the oil return line that goes into my oilpan. Then there are the mounting brackets, two of them and assorted pullies.
The Air Intake piping with U joints. You can also see the 2-BAR MAP, the blue fuel injectors in the ziploc are Ford Cobra SVT #39 injectors. You can also see the SCT and bypass valve. You also see my split second computer I use to control my alcohol injection system along with wiring harness.
Another shot of it all layed out.
How tight of a fit is it? This pic is old but it gives an idea.
Note the broken A/C lines, lol. This let to a violent decompression. Also, in this pic I have yet to install the split second harness or alky system.
How she looks today. Nice clean and organized as best I can for now.
File Type: jpg
Old Aug 1, 2009 | 07:13 PM
blakdak07's Avatar
blakdak07
Wow! That's a lot of stuff. How much time did it take, all & all?
Old Aug 1, 2009 | 07:17 PM
Blown287's Avatar
Blown287
Initial install was about 18-26 hours or so depending on how you look at it, lol. The hard part was making everything fit since the kit is designed for a Ram. I had to relocate the air temp sensor, modify the water temp sensor so I could fit the 2-BAR MAP, had to dremel the inside of the engine bay to fit the blower and I had to have a hydrolic shop fabricate new A/C lines you see in the bottom picture.
Old Aug 1, 2009 | 07:22 PM
canadiandodge's Avatar
canadiandodge
thats a tonne of stuff and it looks awesome all said and done
Old Aug 1, 2009 | 07:32 PM
blakdak07's Avatar
blakdak07
Wicked setup buddy.
Old Aug 1, 2009 | 09:27 PM
Blown287's Avatar
Blown287
Thank you gentlemen, I'm proud of it.
Old Aug 1, 2009 | 11:23 PM
bondslayer's Avatar
bondslayer
That sure does look custom! Nice job, and best of luck on truck of the month nominations!
Old Aug 2, 2009 | 09:44 AM
graythang's Avatar
graythang
Like I said most of us dream of what your truck already is. If could affort to turbo & tune and have another truck for evey day then I would. Tell your wife the 2010 Ram is a must to save gas. lol
Old Aug 2, 2009 | 11:10 AM
Jaded's Avatar
Jaded
Many already commented they would have voted for him if it wasnt for those headlights. So until somethings done there, I don't see it happening
I bet as far as time spent, the majority was researching the fueling, air and all that...finding the parts needed. bet the install was nothing compared to that.
Old Aug 2, 2009 | 12:04 PM
Blown287's Avatar
Blown287
Thank you and Jaded you are correct. I spend several hours on research brefore starting. I had alot of help and advice throughout my build. Richie, Bondslayer, Hemifever and Kevin (who sold me the kit) who gave me invaluable advice. The hardest part was relocating everything and making it fit.
Sorry guys, I love the headlights
