Old Aug 6, 2015, 12:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Trailer Tow Wire Harness 7-Way
Old Aug 13, 2009 | 11:08 PM
TomC's Avatar
TomC
Default Trailer Tow Wire Harness 7-Way
I have a 2007 3.7L Dak Quad Cab with the Mopar Tow Hitch. I just bought the Mopar wire harness for a 7-way connector (part# 82209045). It was easy to install; just unplug two conector pairs behind the front left wheel and plug in the "T" section of the harness. Connect ground to the frame and +12V to the battery terminal and you should be good to go.
But it doesn't work! I buzzed out the wiring and all the connections are good, it just seems like the harness is T-ing out the wrong connector pins. The harness T's out pins 1 and 8 on the 10-pin connector and pins 9 and 14 on the 14-pin connector. But the parking lights, for example, show up on pin 11 of the 14-pin connector; not used by the harness.
This should be plug and play, but it isn't! Anyone have any experience with this part? What am I doing wrong?
Old Aug 14, 2009 | 08:25 AM
Dak_in_Black's Avatar
Dak_in_Black
IIRC, it wasn't plug and play...there was a connection to cut into and solder...maybe they came out with a newer harness?
Old Aug 14, 2009 | 12:51 PM
ahicks's Avatar
ahicks
Just a guess, but is the power to the various 7 wire connector functions run through some missing relays or fuses/circuit breakers located somewhere up front?
I would doubt the factory 7 wire harness would need to be spliced in to the OEM harness? Agree that should be plug and play.
Old Jun 10, 2011 | 09:00 AM
damyankee84's Avatar
damyankee84
Yes I know it's an old thread. But I was wondering if you ever found out what was causing your problem??
Old Jun 10, 2011 | 01:30 PM
TomC's Avatar
TomC
I have the wrong harness. For my model year (2007), the design changed to incorporate an electrical box that I assume contains a few relays. The harness that I have, for earlier years, is just wiring - no electrical box. The connectors are the same for both harnesses, but the pin assignments changed. The new harness, by the way, would require one soldered splice. I ended up splicing in a four-wire connector to the tail-light wires, which got me through the vacation that I was preparing for at the time. I put the harness on the shelf, intending to make it work later, but the four-wire hack job has done just fine and the old harness still sits there.
As an aside, I tried to return the harness to the dealer at the time to trade it in for the correct one, but since I had opened it and it was not pristine, they would not take it back.
Old Nov 11, 2014 | 04:44 PM
djsilverjohnson's Avatar
djsilverjohnson
I just figured out a similar problem with my 2006 Dakota. I bought the truck used in '08 and didn't realize my backup lights weren't working until my neighbor told me. I followed it through the FSM wiring manual and couldn't figure anything out. I took it to a dealer and they pulled some codes and sent them to the Dodge engineering dept., but never got anything back. Yesterday I did some tracing and figured out that the Mopar #82209045 wiring harness (that is designated for my year and model, without the factory tow package) is pinned incorrectly. It has the reverse light power (white/light green) swapped with a ground, so when the Front Control Module tries to power up the reverse lights, it connects straight to ground. I disconnected the jumper tee from the harness (connector C106 behind the mudflap at the back of the drivers side front wheel well) and plugged it back in the original way and the short to ground went away. BTW, I have an electronic FSM for the 2006 version and a hard copy for the 2007 model. The 2007 has one extra wire at pin 9, but the rest are in the same position. I had cut the reverse wire away from the FCM harness chasing the ground, so I'll have to re-connect it to see if the reverse lights will work now (when I get it back from my son...., ;-)
