This is weird!!!
Old Aug 19, 2009 | 05:32 PM
dakota_raven's Avatar
dakota_raven
Default This is weird!!!
For the ones that know a little bit about this matter (like BLOWN) maybe you can explain this that i just found on ebay!!! I don't know if it works or not.
http://cgi.ebay.com/ebaymotors/Dodge-Supercharger-Turbo-Dakota-Neon-Intrepid-Stratus_W0QQitemZ330273725104QQcmdZViewItemQQptZMo tors_Car_Truck_Parts_Accessories?hash=item4ce5d91a b0
Old Aug 19, 2009 | 06:05 PM
snipingdude's Avatar
snipingdude
Hmm it just looks like rip-off written all over it. Idk but by looking at it and being its electric Im assuming it wouldnt need the engine or exhaust gases to spin the impeller...idk it looks weird and it seems like its plastic =P lol
Old Aug 19, 2009 | 06:27 PM
baracis's Avatar
baracis
It's a bilge pump...and yes, it is a rip off...also known as an electric turbo
Old Aug 19, 2009 | 06:28 PM
baracis's Avatar
baracis
http://www.youtube.com/watch?v=NncTM9DEf8Y
Old Aug 19, 2009 | 09:19 PM
Altair's Avatar
Altair
Dak attack!
If you're looking for power save your money, none of these fans are capable of building pressure and in fact will probably decrease your performance. You are putting something in the path of airflow which can't create any meaningful pressure increase to speak of. The speed of the wind created on an open bench really doesn't tell you much, how about the volume of air it can flow? (CFM) How much of a pressure increase will you get from it? (psi, bar, aka boost) How restrictive is having that in the path of air vs without it?
I can build one of these things for a pretty low cost but it would be absolutely pointless, save your money unless you just want something neat looking for your desk in which case a $12 computer fan, a bit of spackle, and some small ducting will accomplish that goal.
Old Aug 19, 2009 | 10:44 PM
dakota_raven
I'm not thinking about buying one! I wanted to know if it worked or not because there a lot of guys here that had spent a lot of money on their trucks and then i come across this and i'm telling myself "Self, this must be a rip off"
Old Aug 20, 2009 | 12:34 AM
graythang's Avatar
graythang
WOW a **** house fan for the truck. Now I can fan for my pop-up john.
Old Aug 20, 2009 | 12:38 AM
Blown287's Avatar
Blown287
Yep you want to avoid those, your engine sucks more air than that thing pushes. It might be ok for a weedeater or something along those lines.
Old Aug 20, 2009 | 09:44 PM
studlyblueiz's Avatar
studlyblueiz
not to mention it'd be pretty embarrassing driving around.
"hey, you hear that vacuum cleaner pull up"
