Need Help (lift and Skid Plate)
Old Sep 2, 2009 | 09:29 PM
sullysdetailing's Avatar
sullysdetailing
Default Need Help (lift and Skid Plate)
I have the 2.5'' Ready Lift Leveling kit on my truck. Since I got the Ready Lift I have put 32.8" BFG Mud Terrian on the truck. Since I got the leveling kit The back of the truck is lower then the front. Anyone know how to fit this? Also the trucks not the high and I love messing arounf off road, is there any company that makes a skip plate for the truck
Old Sep 3, 2009 | 12:27 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Yes, its an easy fix. Do what alot of us have done:
Get 2" axle lift blocks, advanced auto kits, which run $25 come with the exact blocks you need, as well as perfect u-bolts for the 8.25 rear end.
There painted steel blocks, and grade 6 u-bolts. I run them, and so do a few others. Works great.
Old Sep 3, 2009 | 09:29 AM
popsnbeer's Avatar
popsnbeer
and hopefully you have the 8.25" rear end (comes w/ the V6's), b/c don't ask me about making those U-bolts fit onto a 9.5" axle that I have! LOL!
Also, I only did 1.5" rear blocks and the ride height is about level from the front w/ the 2" over the strut spacer.
Old Sep 3, 2009 | 10:56 AM
sullysdetailing
Do i need to get new shocks?
Old Sep 4, 2009 | 02:36 PM
projektdirtfab's Avatar
projektdirtfab
you could get some 3/16 or 1/4" steel or aluminum and get creative with a skid plate...
Old Sep 4, 2009 | 10:58 PM
sullysdetailing
Thanks. Is there any way I can add like a 1'' shim to the front to add some hight
Old Sep 5, 2009 | 12:58 AM
projektdirtfab
shim? don't you have a spacer? if you REALLY needed to you could put a thick washer between the strut and the bracket on the frame... not recommended though...kind of a southern trick
Old Sep 5, 2009 | 03:31 AM
baracis's Avatar
baracis
See if any online junkyards have some. You might get lucky.
Old Sep 5, 2009 | 10:22 AM
MonkeyWrench4000
Don't shim it sully, its too much. 2.5" is the absolute max. Anymore your playing with fire.
