Seat Belt Light and Chime
Old Jan 6, 2010 | 01:31 PM
alltoys's Avatar
alltoys
I have an 05 Dakota with the same problem, belt lite and chime thingy. I did try to get remove the drivers side seat then found out the center section and passenger side is all bolted together. Factor in it was -20 out I decided to leave it alone till weather warmed up. ( Glasses fogged up too )
After about 10 minutes the chime stops but the little red man still beams at me. I did find the fuse to eliminate the chime but it removes all functions from the dash. Speedo, eng temp, tach, all the necessary functions I need.
I am going to print off this temporary fix see how it goes then wait for a warm day to a permanent fix.
Thanks Lightning Bolt.
Old Jan 7, 2010 | 04:41 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
No problem buddy, anytime!
Old Jan 9, 2010 | 09:38 PM
alltoys's Avatar
alltoys
I tried the fix unfortunately it didn't work. The seat belt indicator doesn't go out at all for the start of the fix. Still tried it with no success. Tomorrow is warmer out so will pull the seat apart see if I can find out the problem.
Old Jan 11, 2010 | 10:06 PM
alltoys's Avatar
alltoys
I did try the fix but it didn't work for me as the light did not go out to start the fix.
So I had to pull the seat out both driver and passenger as the center counsel was attached to both sides. Once got the passenger side seat out it was easy to pull apart the wiring in the seat buckle and under the seat itself. I found the small saulder connection in the seat buckle to be the culprit so I cut the wire completely and sauldered it together. Now with no way for it to crimp there is no more dingy going off in the cab and no more little man glowing at me. Thank goodness it was driving me nuts.
Old Jan 12, 2010 | 08:30 AM
lghtngblt02
Glad you got it fixed man! That would drive me nuts. I know mine dings for like 2 minutes and then gives up on it until you restart
Old Jan 13, 2010 | 12:33 PM
alltoys's Avatar
alltoys
Try your seat buckle it is probably the culprit. If you can get to the guts of it without removing the seats you will be lucky.
Old Jan 13, 2010 | 01:09 PM
lghtngblt02
No no, my works properly. I meant if I dont put my seat belt on it'll ding for about 2 minutes and then it gives up. If I put it on it quits. All normal
Old Mar 15, 2010 | 10:20 AM
mTn_biKer65's Avatar
mTn_biKer65
Thanks for posting the fix lghtngblt02, it worked like a chime.
Old Mar 17, 2010 | 01:51 AM
jeepdakota's Avatar
jeepdakota
thank you i'm going to try it. i hate buckling to go up my driveway after checking the mail. seriously, that chime is annoying!
Old Oct 26, 2010 | 02:51 PM
suprcharg's Avatar
suprcharg
Thanks for that advice. That annoyed the heck out of me!!
