33" tires on factory ride height dakota
Old Sep 13, 2009 | 10:15 PM
  #21
mprohr's Avatar
mprohr
nice truck rail
Old Sep 14, 2009 | 12:29 PM
  #22
coondog05's Avatar
coondog05
POPS, its not the front bumper itself but the inner fender well.... not a big deal there. you could trim most of that away if needed.... the back it the issue! and sleds, try a quarter or half inch wheel spacer for the frame rub. its gonna make the rub on the flap worse but it will help the frame rub for sure! mine rubbed so much with a half inch spacer i cut the fender itself under the flap then put the flap on and cut it back as well....again use thick tie wraps and tug the inner fender behind the flap in and reinstall the flap and youll gain around an inch of clearence where the major rubbing issues are...i have 16 inch rims on 285/70,s...17 inch tires and 285,s might change the dynamics of the setup, i dont know...but this worked for me
Old Nov 4, 2010 | 07:20 PM
  #23
jayz442's Avatar
jayz442
265/75/16 worked on my 2wd 98 dakota i removed the inner plastic front fender liners but gave it a great 4x4 look only rub when cut wheel deep and truck is going thruogh rough terain
Old Nov 5, 2010 | 11:01 AM
  #24
dakota_raven's Avatar
dakota_raven
Man, this is an old thread!!!! LOL...
