Exhaust Manifold Leak?
Old Sep 11, 2009 | 09:07 AM
pack154's Avatar
pack154
Default Exhaust Manifold Leak?
I noticed this morning my engines sound different. It sounds like the exhaust is leaking near the motor so I assume it's the manifold bolts that have come loose or broke. I've read some threads about this happening. I plan on doing this myself unless the bolt or bolts are broken. Any tips would be appreciated.
Old Sep 11, 2009 | 01:17 PM
Phoenix.no624's Avatar
Phoenix.no624
Default Possibly...
Its possible, I have a 1995 Jeep Wrangler and it was pretty apparent that it had a cracked exhaust manifold. What you can do is start it cold, pop the hood, and rev the engine up and if the sound gets louder while the engine is in the process of accelerating and then quiets down once it stops accelerating then that's most likely the problem.
My Jeep made sort of a snapping sound, just flick the throttle a bit and see if it becomes more apparent and then quiets down. Optionally, if its really bad, you could buy a vacuum gauge and check the engine vacuum. I would think that a REALLY bad leak like a loose manifold flange would cause the O2 sensor to cry foul to the computer which would throw a code but you never know...
Old Sep 11, 2009 | 01:33 PM
pack154's Avatar
pack154
It does get louder when I rev the engine. I don't really notice it when I'm driving. I'll have an update later today once I have a chance to look at it.
Old Sep 12, 2009 | 10:46 PM
pack154's Avatar
pack154
I'm surprised nobody "called me out" on this and told me to stop being lazy and do a forum search.
I haven't tackled this yet, I'm going to see if my extended warranty will cover it.
Old Sep 12, 2009 | 11:45 PM
Altair's Avatar
Altair
Dak attack!
Use the SEARCH you Noob!!!
Just kidding . Let us know how it goes.
Old Sep 13, 2009 | 09:02 PM
pack154's Avatar
pack154
LOL! There ya go Altair, I'm surprised nobody did that earlier.
If my extended warranty doesn't cover it, I'm going to do it myself, but I'm pretty sure it will. I'll update tomorrow.
Old Sep 13, 2009 | 10:02 PM
mprohr's Avatar
mprohr
You almost certainly have a busted stud at the back of the manifold nearest the outlet. This will require extracting the busted stud. sometimes easy, sometimes hard. If you have never used a tap to extract a bolt, I wouldn't practice here. 8mm studs are used oem and are too small for the application.
Old Sep 15, 2009 | 07:35 PM
pack154's Avatar
pack154
I took the truck into the shop today and they said it was a cracked exhaust manifold and my extended warranty will cover it. I should get it back tomorrow if they don't have any problems getting the bolts off - I let them know to go ahead an antisipate busting a couple of them.
Old Sep 15, 2009 | 10:50 PM
mprohr's Avatar
mprohr
Will your extended warrenty cover some new JBA shorties?
Old Sep 16, 2009 | 06:51 AM
pack154's Avatar
pack154
Lol - That would be nice.
