Dakota won't turn over??
Old Oct 2, 2009 | 02:06 PM
vette68's Avatar
vette68
Default Dakota won't turn over??
I just drove my Dakota home, shut it off, ran inside, and went back to go back out and the truck won't turn over.
Checked all the fuses at the dash fuse box, all good.
Seems like the normal cluster light are acting funny when I turn the key to the on. (might just be me)
Very faint clicking noise when I turn the key to start.
Also it's raining out side!
Old Oct 2, 2009 | 02:15 PM
Cuban11182's Avatar
Cuban11182
Check negative terminal make sure it's connected tight. Mine did the exact same thing and that's what I found.
Old Oct 2, 2009 | 02:37 PM
vette68's Avatar
vette68
almost seems like that, I just finished re doing the terminals, the positive was courroted, cleaned it but still nothing.
Old Oct 2, 2009 | 02:42 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Bad battery would be my next guess, or the starter is toast? Have some turn the key and while they are turning the key take a hammer and tap the side of the starter, if it begins to turn its most likely the starter is going.
Old Oct 2, 2009 | 03:00 PM
vette68's Avatar
vette68
just re did the battery terminals, and the ground on the inside of the fender.
I can't even test the battery, because all my electrical tools are in my service truck. which I don't have today!
I'm thinking more to the bad battery, because my keyless door locks won't work either.
Interior lights are on though, maybe a little dim.
Old Oct 2, 2009 | 03:06 PM
canadian dakota's Avatar
canadian dakota
altinator maybe just throwing ideas out there im here to learn I've already discovered I can't trust a dealer
Old Oct 2, 2009 | 03:09 PM
vette68's Avatar
vette68
Just through the battery charger on it. lets see if it holds a charge!
Old Oct 2, 2009 | 03:19 PM
canadian dakota
hopefully that works and its just due to a light left on lol
Old Oct 2, 2009 | 05:02 PM
lghtngblt02
ahh ok then I would lean towards the battery too
Old Oct 2, 2009 | 05:38 PM
vette68's Avatar
vette68
I just installed a new battery, and it started right up.
If it was the Altinator how long will it take for the battery to go dead? The truck seems to be running rough now. Maybe the Altinator surging????
