Odometer Error
Old Nov 12, 2012 | 06:06 PM
Tom A's Avatar
Tom A
Section Moderator
Originally Posted by dakotaff
I'm not sure about the answer, but $570 to replace it was way out of line. The instrument clusters are $50 to $100 on ebay, and it's pretty easy to swap out.
What's going on with yours?
I don't know any shops that buy their parts off of ebay. And I know the labor rate around here is $125-150 an hour. So, if you figure dealership list pricing on the cluster and an hour labor, it wasn't really out of line at all.
Old Mar 25, 2013 | 01:40 PM
flyinfool's Avatar
flyinfool
My 2005 dakota has the same odometer error. Anyone know where the input signal comes from, the xmission? wheel sensor? thanks - - flyinfool
Old Mar 25, 2013 | 02:53 PM
Believe he means the price is typical for a stealership and way out of line considering you could get a used on off ebay for that price and do it yourself.
Old Mar 25, 2013 | 02:56 PM
Welcome to DF. You should start your own thread. You will get more traffic and visability to your question that way.
Old Mar 27, 2013 | 01:03 PM
flyinfool's Avatar
flyinfool
My 2005 Dakota same error - -I did the test holding down reset button -turn key on-release reset button and test began went thru 7 steps with tach and speedometer displaying readings at each step for one example -speedometer at 30 and tach at 2 which I read as 32 ? At end of test, odometer read 50600 then went back to error. The milage shown was not my last milage. Is this an error code ?? Also, anyone know how hard it is to remove the inst. cluster?? Also where the odometer input signal comes from, the tranny? or wherever? Any info appreciated
Old Mar 27, 2013 | 04:31 PM
dakotaff's Avatar
dakotaff
Exactly what I meant. Of course the dealer will rape you as usual.
The instrument cluster is pretty easy to remove and replace, below is a thread showing how to do it.
That may or may not eliminate the error code.
Thread
Old Mar 28, 2013 | 09:42 AM
mattz's Avatar
mattz
I just bought a used cluster yesterday and am going to try and replace it this weekend. Hope it works. I will update when done.
Matt
Old Mar 29, 2013 | 04:48 PM
mattz's Avatar
mattz
I have started a new thread on this topic.
Old Jul 9, 2014 | 01:43 PM
drrythm's Avatar
drrythm
Default odometer error
Did you ever find the solution to this? I have the same problem
Old Jul 9, 2014 | 01:45 PM
drrythm's Avatar
drrythm
Originally Posted by utahdakota
After starting my 2005 dakota this morning i recieved an error message on my odometer. No check engine light, or anything else seemed wrong. It seems to run just as good, with no apparent reason for the error. I recieved no error codes when attempting to get them. Has anyone else had any of the same problems and if so how have you resolved them? Is there anyway to do a reset and see if this clears the error message?
Any help would be appreciated, if the error doesnt correct itself i'll have to run down to the dodge dealer and have them give it a look over, so far they've said just to look it over it'll cost over a hundred bucks, so hopefully it wont come to that. This poor school boy cant afford that :P
Did you ever find a solution to this? I have the same problem
