Broken exhaust bolt
Old Jan 14, 2010 | 04:30 PM
ixc's Avatar
ixc
bump. im looking to tackle the bolt this weekend if i can just get the length.
anybody out there know?
Old Jan 14, 2010 | 04:56 PM
projektdirtfab's Avatar
projektdirtfab
it happens to the best of us. i work alongside a ex-dodge tech that said daks came in left and right with broke mani studs. he had a bunch laying around that i used on mine. i did my drivers side (mani removal, surface clean, and new gasket and hardware in about an hour.) in my garage where i do all my work. if its the rearmost bolt it has a stud on the outside also for the shield (which i left off) so you cant use a regular bolt
Old Jan 14, 2010 | 05:36 PM
ixc's Avatar
ixc
thats the one in question. I know its a stud but i figure a bolt will work just fine and leave the heat shield suspended by the 3 working studs as it has been for some time.
i may just end up pulling the whole thing and then running to the HW store w/ bolt #2 shown in the service manual to find a replacement but i was hoping to get it done in one sitting.
Old Jan 16, 2010 | 05:53 PM
ixc's Avatar
ixc
here to answer my own question for future reference.
the exhaust manifold bolts are 8x1.25x45mm. 5mm of that is the taper at the end. I used a 40mm just fine.
Old Jan 17, 2010 | 11:14 PM
mprohr's Avatar
mprohr
You'll fit in nicely here
Old Jan 18, 2010 | 10:52 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Thanks for letting us know! Its greatly appreciated!
