"Change Oil" Warning
Old Nov 18, 2009 | 06:15 PM
flamered06's Avatar
flamered06
Default "Change Oil" Warning
Does anyone know the protocol for turning off the little telltale "Change Oil" warning located under the odometer on an '08 Dakota? I had a lube job done the other day and it's still on.
Old Nov 18, 2009 | 06:23 PM
Frenchy's Avatar
Frenchy
check manual?
Old Nov 18, 2009 | 07:31 PM
paul05dak's Avatar
paul05dak
I would bring it back to where you got it don, have them reset it, and have them tell you what they did for your inconvienence. Also tell them you want to know for the next time they change your oil you won't have to bring it back a 2nd time!
Old Nov 18, 2009 | 07:52 PM
08sxtdakota's Avatar
08sxtdakota
hey man, yeah all you gotta do is turn the key to the on position dont start it though pump your gas pedal 3 times within 10 seconds turn the key back off then start your truck it should have went off by the time you start it.........just dont start it turn the key to the on position pump your gas pedal 3 times within 10 seconds then turn your key off, then start it that clears the oil light......
Old Nov 19, 2009 | 11:44 AM
popsnbeer's Avatar
popsnbeer
what he said ^
Old Nov 20, 2009 | 11:07 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by Frenchy
check manual?
Aren't we helpful...
Old Nov 20, 2009 | 11:28 AM
Frenchy's Avatar
Frenchy
mine doesnt have this warning...
So, sorry I couldnt' be more specific than EXACTLY where to find it.
Old Nov 25, 2009 | 06:09 PM
flamered06's Avatar
flamered06
Thanks for the info 08SXTDAKOTA. Worked like a charm.
