Bedliner/TuneUp questions?!
Old Nov 26, 2009 | 06:58 PM
  #31
mmullengs's Avatar
mmullengs
Go with a bed rug you won’t regret it
Old Nov 27, 2009 | 01:54 PM
  #32
trucky's Avatar
trucky
I would get bed rug if I had a tonneau cover...
Old Nov 27, 2009 | 04:53 PM
  #33
Frenchy's Avatar
Frenchy
Originally Posted by ericemery
its called a door buster frenchy... just like they cant do an oil change for 4 bucks...
The jiffy lube has them advertised at 89.00 in the paper today...
And explain to me why a dealer would do a partial flush? that logic doesn't make sense.
Idk, just seems crazy.
Maybe it's just me and being used to a trans flush costing my dad 130 - 150 bucks up here...
Old Nov 28, 2009 | 12:55 PM
  #34
deadmouse's Avatar
deadmouse
Memories-0036.jpghey, i'm new here but i do the spray in liners and have sprayed line x and reflex. the reflex is a far better liner. it stays pliable at -50 and does't crack, flake or peel. in canada i charge $400 under the rail and $500 over the rail for short boxes, add $50 each for long box. it's a poly urathane just like the stuff they use to install windshields.
Old Nov 29, 2009 | 10:03 AM
  #35
superdak05's Avatar
superdak05
DO NOT GOT TO JIFFY LUBE, SPEEDY LUBE, OR SH!TTY LUBE, for any trans, differential, fluid change, go to the dealer. i bring my truck in every 30000 miles, for all this. i currently have 86000 miles on it, so it is do for a change soon you may pay a little more, but the dodge gurus, know more about the mechanics of the truck, than joe , moe, at the quick change place. as for the tune up, thay will change all plugs, put truck on the emissions machine, check all sensors, gas cap, cats, update pcm, if there are updates, there were for my truck, check brakes. everything inside and out, the tune up is 380.00, some peole say a that much for 8 plugs, but its the tuning software that they use is whats pricey, the tranny flush is 119.00 and both diffs were 89.99, i do my own tune ups because of the sct tuning, but i let dodge do the rest, somethings u you just dont want to deal with, and the mess, forget it, hold off on the tune up, get all the fluid change first, all 8 plugs at walmart are 20.00, but a fried tranny around 3000.00
Old Nov 29, 2009 | 06:01 PM
  #36
trucky's Avatar
trucky
Rock on, dodge it is. My differentials were leaking this summer so they are already freshly changed out, theres $90 saved, and I can do my own sparkies. Hopefully dodge will do all those checks and the tranny flush for under 300. Thanks~
Which spark plugs do you recommend???
^ joke
