considering fabricating a lift
#21
#23
I've said a couple times on this board about using part of rancho's 2000-2002 Dakota kits to lift our truck. Read the bottom of page of install instructions 5, 6, & 7:
http://www.performancelifts.com/inst...cho/RS6560.pdf
Pulled that from: http://www.performancelifts.com/cgi-...rt/RS6560.html
That's how I'd lower the axle with that piece part of their kit. If you look at the actual pics and then your truck you'll notice that design is still the same. I don't know if the lowering brackets would work. You'd need to have one in front of you or do research to compare what parts have still stayed the same around the knuckle area. The axle spacer concerns me...I assume it's to counter the wheel moving deeper into the wheel well. If so most of us with leveling kits already lost track width anyhow.
Steering I'd just ream the knuckles to place the tie rod on top.
Brake hoses may be reusable. Just rebend or remount lower.
Rancho sway bar kit may still work. If not, I'd use square tubing and make a spacer.
Transmission spacer & drop bracket...would be nice if rancho's was reusable.
Then just use TM level kit and one like Rough Country for front lift. Then finish with blocks in the rear.
