Question about a boost/vacuum gauge
Old Dec 19, 2009 | 05:29 PM
  #21
Frenchy's Avatar
Frenchy
Ummmm.... ok, issue.
Just went out to look at the truck, and where you are showing me, I have NO line there.
Its closed off, there's a nipple, if you will, there, and I thought it was just unhooked, or something, so I took a 1/8 drill bit, and kinda poked it in there, by hand, and it's sealed off...
umhmmm............. help?
Old Dec 19, 2009 | 10:35 PM
  #22
Blown287's Avatar
Blown287
Does the nipple remove? If so, remove it and run a vacuum line into it.
Old Dec 19, 2009 | 10:44 PM
  #23
Frenchy's Avatar
Frenchy
no... Idk what to do now...
...could I take the intake and throttle body off... and SOMEHOW drill the hole out??? it's like, solid there...
Any tips if I do this? I don't want any plastic in the motor...
Old Dec 19, 2009 | 11:04 PM
  #24
donkeypunch's Avatar
donkeypunch
King Jackass
Frenchy, PM me with your contact information. I will help you over the phone. I have a small amount of experience with a "boosted" application.
Old Dec 19, 2009 | 11:33 PM
  #25
Frenchy's Avatar
Frenchy
lol, Donkey, I think you have more than a "little" amount of experience haha... your TSi is a monster.
Old Dec 20, 2009 | 12:07 AM
  #26
Blown287's Avatar
Blown287
Frenchy, I monitor directly at the manifold because I'm forced induction. You can plug almost into any vacuum line to monitor the pressure.
Old Dec 20, 2009 | 12:09 AM
  #27
Frenchy's Avatar
Frenchy
I'm gonna take the intake and throttle body off, and the little fitting that your vacuum line slips over, has about an inch that a 1/8" drill bit can go into, and then from there, I can just drill out the rest...
that way I can run a direct line to the gauge.
Old Dec 20, 2009 | 01:18 AM
  #28
Blown287's Avatar
Blown287
Thats cool Frenchy. I know monitoring vacuum/boost off that spot on the manifold has been accurate. They match the dyno graphs 100%.
Old Dec 20, 2009 | 01:23 AM
  #29
Frenchy's Avatar
Frenchy
Lol, good.
When you showed me that line I was like, well that's simple enough, then I went out and looked, and went into instant panic mode.
I had no idea wtf to do.
Old Dec 20, 2009 | 01:26 AM
  #30
Blown287's Avatar
Blown287
If you go with boost, it only gets worse. All the fabrication and relocation that goes with it is crazy.
