Got my lightbar all installed... :)
Not sure where you live but it rains here pretty much 12 months out of the year. Along with that, there's the dew, frost, and other airborne moisture that attacks non rust-inhibited metals. Zinc-coated metal like those brackets/bolts/screws/nuts don't stand a chance against the elements.
This is probably just me, but I won't put any type of hardware on any of my vehicles or toys that isn't impervious to rust. If it's not aluminum, stainless, or painted metal, I won't use it. Once those start to rust, it will compromise the finish (and eventually the body panel, since it was drilled) where those brackets are installed. Over time it will rust the gate, guaranteed.
where to mount the sender? I tried taking the oil pressure switch off, and it's not budging...
So I think I may end up having to go with an oil filter sandwich adapter. But if I don't have to, I'd rather not.
It has been a while since I was under the truck, it is tucked away for winter. Anyway...
Isn't there 2 plugs right by the oil filter that you could use? IIRC I have 2 and I will be using each one. One for my temp gauge, and the other for pressure.
Something just dawned on me, I am not sure if you have a V8 or V6. I would go back a page a look, but this board has never been slower for me and keeps freezing solid.
I will take a peek under my truck later, when my bad back gives me 5 mins of peace.
There are other areas to tap into oil pressure, but the most common is near the filter. Other places will give different readings and you will need to know just what they should be for that given area.
I figured I have to at least remove the oil filter to get to it, either way... but ya... I can't figure it out...
Unless old age has really taken hold, I am almost positive there are 2 plugs right next to each other.
I'd go and check now, but if I get under the truck, I won't be coming out. May back is that bad.
I'll do a search on line for a pic just incase.
