more crazy blinker behavior
Old Jan 7, 2010 | 10:47 AM
bain64's Avatar
bain64
Default more crazy blinker behavior
With my blinker on, it will sometimes make the 'tick' noise that alerts you a turn signal is on, other times it will not. At first I thought that it would tick for 5 seconds or so and then turn off to not annoy the driver, but now I can't find any rhyme or reason to why or when it ticks.
Anyone else have something similar? Does yours tick all the time or none?
Old Jan 7, 2010 | 03:47 PM
paul05dak's Avatar
paul05dak
Bain, sorry I have no idea, My stereo is normally too loud to hear the directional. It doesn't sound normal though. hopefully someone here will chime in with a better answer.
Old Jan 7, 2010 | 10:04 PM
Altair's Avatar
Altair
Dak attack!
Mine ticks every time.
Old Jan 8, 2010 | 10:30 AM
biker_ahoy's Avatar
biker_ahoy
You might check the blinker relay ( wherever that is) it might be loose or you might need a new one, if the ticking stops all together, I would just leave it, I'm not a fan of that sound anyways. (wish I could turn it off)
Old Jan 8, 2010 | 02:24 PM
Dak_in_Black's Avatar
Dak_in_Black
Talking
Use this...makes it nice and quiet....
Old Jan 8, 2010 | 04:27 PM
popsnbeer's Avatar
popsnbeer
i sense sarcasm in this thread..................HAHAHAHA!
Old Jan 9, 2010 | 10:08 AM
bain64's Avatar
bain64
Yes my mechanic already flushed and replaced my blinker fluid, but I did not ask for the synthetic perhaps that is the problem. I paid a little extra and he let the summer air out of my tires and replaced it with fresh winter air, i couldn't feel the difference but my tires shouldlast longer now.
Old Jan 9, 2010 | 10:10 AM
bain64's Avatar
bain64
I will swap that relay with another similar one and see if that helps. Thanks. Too bad it is negative 8 degrees F here in Illinois or I would check right now.
Old Jan 9, 2010 | 11:35 AM
Altair's Avatar
Altair
Dak attack!
That always puts a damper on working on the truck, I miss being able to take over my parents heated garage back in Maine, luckily Jersey isn't quite as cold.
