Another Spark plug question ?
Old Jan 30, 2010 | 10:28 PM
biker_ahoy's Avatar
biker_ahoy
Default Another Spark plug question ?
Picked up six NKG Iridium plugs #018-4750-0
Just wanted to confirm I had the right ones.
And also ask what's the gap is supposted to be for my 2007 3.7L V6
I was also reading the back of the package and it says
"Important Do Not adjust spark plug gap due to extremely fine center electrode.
I assume I don't need to adjust the gap but want to double check the gap and make sure this is all good before I go ahead and install.
Thanks
Old Jan 30, 2010 | 11:54 PM
ReturnToSender's Avatar
ReturnToSender
ZFR6F-11G
Gap (0.042 in.)
Old Jan 31, 2010 | 12:28 AM
biker_ahoy's Avatar
biker_ahoy
ZFR6FIX-11 is the number on the pack.
The gap tool I have doesn't have 0.042
closest I have is 0.044 which is a tiny bit big so your prob right on. but I also checked the NGK site and they say 0.044
http://www.ngksparkplugs.ca/results-...A&aaia=1434470
I'm sure your right though.
Old Jan 31, 2010 | 03:13 AM
Slick Dakota's Avatar
Slick Dakota
I posted something but changed my mind about this certain type of plug.. Cya Slick
Old Jan 31, 2010 | 04:57 AM
biker_ahoy's Avatar
biker_ahoy
I've been through every thread on spark plugs I could find, there's not a lot of info on the 3.7L engines,
I'm going to look under the hood this afternoon to see what it recommends.
any other input?
Old Jan 31, 2010 | 07:47 AM
ReturnToSender
Don't forget to shoot some compressed air into the holes before you remove the plugs from the motor or else you might get dirt in the engine.
Old Jan 31, 2010 | 08:42 AM
superdak05's Avatar
superdak05
i always run the autolite 3922 plugs, the nitros system likes these plugs, but before going all out on the motor the autolite 3923 plugs were great. they are one heat range cooler than stock champions
Old Jan 31, 2010 | 11:27 AM
Blown287's Avatar
Blown287
I'm running NGK BKR7E, stock# 4644 in my blown 4.7L. They are one heat range colder than stock.
Old Feb 2, 2010 | 06:15 PM
hendrixx324's Avatar
hendrixx324
I also have a queston about spark plugs... There are E3.64 and E3.48 by e3 diamnond fire. Whats the diffrence and do they realy add power??
Old Feb 2, 2010 | 08:23 PM
biker_ahoy's Avatar
biker_ahoy
From what I've heard those E3's work best with a higher octane fuel. not sure on the diff between the two models
