dealer says "that's normal"
Old Apr 23, 2005 | 05:08 AM
flyrodder's Avatar
flyrodder
Default dealer says "that's normal"
I just got my new Dakota back from the dealer (late night pick up) and it's no different from when I dropped it off. I took it in for 2 things. 1-the rear door does not latch solid on the bottom on only one side, and 2-the steering wheel does not lock when the key is removed.
The write up on it says they found no problem with the door latch. But if you tug on the bottom of the door, there is a good 1/2 inch of play. The drivers side does not budge. And for the steering wheel lock, they say you need to turn almost a full rotation before the lock will engage.
Have any of you experienced these issues, if so, have you had them checked and what was the outcome.
Thanks
Old Apr 23, 2005 | 10:48 AM
moparturd's Avatar
moparturd
Default RE: dealer says "that's normal"
I can't say that I have, but you may want to find another dealership to look at your truck. 0.5" Holy crap!!!
Old Apr 23, 2005 | 11:20 AM
pgp2002's Avatar
pgp2002
I am going in for service today, I will both check my Kota and see if it does the same thing, and I will ask the service manager about the issue. I will let you know what happens.
Old Apr 23, 2005 | 02:44 PM
wpgdakota's Avatar
wpgdakota
my steering wheel doesnt seem to lock either....also my passenger side door doesnt close as easy as it should and needs to be adjusted....had the exact same door problem on my 01...
