Recommended Battery????
Old Feb 6, 2010 | 11:06 AM
NJJer's Avatar
NJJer
Optima return % due to just being "bad"- Nearly 60% for us. As a whole, as high as 70% at times.
Each and every vehicle has it electrical and charging system gone over to be sure of what's going on.
Yes, we keep very close track of these and report back to Interstate with the info.
I have a list of who makes what batteries. I will see if I can find it and post it here. I know I did over at DT.
You will hear stories of Optima's last 8-10 years. Sure they did, but they are not the same battery that you buy today.
Just stating the facts we have as a dealer.
Old Feb 6, 2010 | 11:18 AM
NJJer's Avatar
NJJer
This list is 2 years old. Things may have changed since then. It was accurate at the time
This may help you with that. I found my list I got from someone on the manufacturers of batteries in the U.S.
A few may have changed, but then again, I don't know if any did.
Johnson Controls Inc. (JCI)
-Ameriton
-Duralast (Contact local Auto Zone store)
-Energizer (Contact local Target or Wards store)
-Equalizer (Contact local Wards store)
-Eveready (800-331-9926 or contact local Costco or Wards store)
-Interstate (800-272-6548)
-Motorcraft (800-392-3673)
-Power Connection
-older Sears Diehards
East Penn (610-682-6361)
-American
-Electro
-Deka
-Hi-Tech
-Pow-R-Surge
Douglas (800-368-4527)
-Farmland (Contact local store)
AC Delco/Delphi (800-223-3526)
-Diehard Gold (Contact local Sears store)
-Double Eagle (Contact local Firestone store)
-Dura Power
-Everstart (Contact local Wal-Mart store)
-Freedom (Contact local Sears store)
-Lastcell (Contact local Trac Auto store)
-Tough One (Contact local Western Auto store)
-Voyager
GNB (800-242-6750)
-Champion (Contact local Sams store)
-Omaga (800-925-6278 or contact local Wal-Mart store)
-Voyager (Contact local Sams store)
Exide (800-346-3760)
-Auto Express (Contact local Wards store)
-Centura (Contact local K-Mart store)
-DieHard non-Gold (Contact local Sears store)
-Edge
-Legend (800-538-6272 or contact local NAPA store)
-Motorvator (Contact local K-Mart store)
-Power-Tron
-Prestolite (Contact local HiLo store)
-Pro Start (Contact local Pep Boys store)
-Quick Start (Contact local Wards store)
-Sears (Contact local store)
-Titan
-Value-Lite (Contact local Firestone store)
Old Feb 6, 2010 | 11:21 AM
bain64's Avatar
bain64
Very nice info! It's interesting that Diehard, and Diehard Gold are made by 2 different companies.
Old Feb 7, 2010 | 02:31 PM
AsphaltCowboy's Avatar
AsphaltCowboy
hey guys, last week i had my truck in for an oil change(free at the dealership) and they tested the battery and they said it was low on charge and they recharged it. i had the truck out earlier and noticed it took a little bit more to start it today. ive got the factory remote start on my big horn and it usually only takes maybe 5 seconds for it to start, but it was more like 15 today and when i got to where i was going and parked it for a few minutes, it almost didnt start. time for a new one? its an 08 with 19k miles on it. does optima make a red top for our trucks?
Old Feb 7, 2010 | 03:53 PM
NJJer's Avatar
NJJer
You sure you want an Optima?
Make sure all cells are filled (if you can) and use battery acid, not water.
To properly test a battery, it must first be fully charged at a slow rate. 2amps/hour is ok. Full charge will take 24-36 hours.
Then you must remove the surface charge from the battery. (There are a few ways to do this)
Then load test the battery- If bad,replace. If good, check the following:
Battery terminals- Are they clean and tight?
Are the ground cable clean and tight where they "ground out"?
Is the positive cable clean and tight on starter?
Is the trigger wire to started clean and tight?
Does trigger wire have full voltage at the starter terminal when key is in start position?
Check alt. output? is it charging at 14+ volts?
That should get you going. If you still have a problem, let me know.
Old Feb 8, 2010 | 07:14 AM
bain64's Avatar
bain64
NJ is just full of useful battery info.
Asphalt, 5 seconds is a long time to crank before she starts, let alone 15. Do you take very short trips back and forth to work or something? Is your alternator putting out? Maybe you should buy her an extra glass of wine or something..
Old Feb 8, 2010 | 08:38 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I have had good luck with Duralast Golds
Old Feb 8, 2010 | 05:41 PM
NJJer's Avatar
NJJer
Comes from being a Master Tech.... that and being extremely **** with everything I do. I hate ever having a customer complain about something I did. So I try like not to give them a reason.
Old Feb 8, 2010 | 07:29 PM
AsphaltCowboy
its ten miles to work for me. i start it up when i get outa the shower every morning and it usually runs for 5-10 minutes in the driveway before i leave. maybe its just the cold weather. it only hesitates on the remote. she'll crank right over with just the key.
haha. oops, i just noticed this was in the dak section. my bad. i guess thats what i get for searching. this is for an 08 1500 5.7 hemi.
Old Mar 5, 2010 | 06:20 AM
trucky's Avatar
trucky
I bought an optima despite the warnings. It is warrantied and I really want to see how it runs with all my electronics for a while, it got great reviews everywhere but here. Just the opposite for napa and sears...I saw bad reviews for them and it was hard to find what I needed. If something goes wrong, or right for that matter, I will report back and go NAPA/Sears if needed.
