High Beam "Bypass"?
Old Feb 10, 2010 | 09:40 PM
FastMagDakotaKid's Avatar
FastMagDakotaKid
All good looks guys thanks alot.
Old Feb 11, 2010 | 06:56 AM
bain64's Avatar
bain64
LOL Dodgetrucker. You just got the modding bug huh?
Old Feb 11, 2010 | 11:06 AM
dodgetrucker75's Avatar
dodgetrucker75
you have no idea... i call it an uncureable diease
Old Mar 21, 2012 | 10:30 PM
Anthony Grego's Avatar
Anthony Grego
couple questions, does anyone have an idea which wire is the computer side one, second any input on how to make the low beams stay on when the highs are turned on. I LIKE IT BRIGHT!!!
Old Mar 21, 2012 | 10:32 PM
Anthony Grego
oh n while im on here n DODGEtrucker cant recieve anymore messages, TRUCKER, where did u get that bumper? i want!!!
Old Mar 21, 2012 | 10:39 PM
dodgetrucker sold his truck and is no longer on the Dakota side (he got a Ram), this is an old thread. He built that bumper himself. Welcome to the forum by the way.
Old Apr 14, 2012 | 10:45 PM
Longlivedakota's Avatar
Longlivedakota
Originally Posted by dodgetrucker75
i just came up with a great idea...maby...
this can be done with one relay, a normal 5 pin square relay found at any parts store
you would cut the wire feeding power to the fog lights, the fog light side of the wire would go to pin 30, the computer side of the wire would go to pin 87A, power from the highbeam circuit would go to pin 85, battery power (+)to pin 87, ground to pin 86,
this will allow normal operation of the fogs when on low beams, but will turn the fogs on all the time when the high beams are on, the only way to shut the fogs off with highs on would be to put a switch in line between the high beam circuit and pin 85,
here is a drawing, its crude but should get the idea...
I did this and it works great! Thanks!
