Trailmaster sag
Old Feb 23, 2010 | 05:34 PM
vito's Avatar
vito
Default Trailmaster sag
I have a 1.5" TM leveling kit, before I had it, the measurement from wheel to fender was 11", after the install was 12.5", 1.5" lift, after a while it when down to 12", lowering it 1/2", after I replaced the shocks with rancho, it went back up a 1/2", a month after the new shocks it went down 1/2". I want that 1/2"or 1" to get a total of 1.5 or 2", should I replace my springs or do a 1" lift spacer on top of the strut? (in addition to the TM kit)
How thick should the spacer be to have a 1" lift? thank you
Old Feb 23, 2010 | 07:22 PM
tdister's Avatar
tdister
There seems to be a consensus to not do 2 leveling kits. I noticed the sam on my truck, though i have a bit over 1" after it's settled. Is your truck 2wd or 4?.
Old Feb 23, 2010 | 10:59 PM
dodgetrucker75's Avatar
dodgetrucker75
did you take the initial measurement after moving the truck, or just when you let it off the jack after the install?
Old Feb 23, 2010 | 11:57 PM
vito's Avatar
vito
its 4wd, I took measurements after I moved the truck, so it could settle, I only have one inch lift now, I used to have 1.5".
Old Feb 24, 2010 | 12:03 AM
dodgetrucker75
strange... havent heard that one, the only real cause is relaxing springs, struts could have some effect, but little if any
Old Feb 24, 2010 | 12:13 AM
vito's Avatar
vito
Thats why Im thinking of putting another spacer on top of the strut to get at least the 0.5 inch back,
Old Feb 24, 2010 | 12:58 AM
biker_ahoy's Avatar
biker_ahoy
warn sway bars will drop the front of the truck a bit too.
I just have both mine replaced and it brought the front end back up to its original height. it was quite noticable.
Old Feb 24, 2010 | 01:12 AM
dodgetrucker75
one thing to add... i added aditional lift to my leveling kit, and due to the lever factor, a 3/8-1/2 spacer will net you about 1inch of lift
