Odd squeak from drivers side rear? Bad gas mileage?
Old Feb 26, 2010 | 04:58 PM
popsnbeer's Avatar
popsnbeer
Question Odd squeak from drivers side rear? Bad gas mileage?
Hey guys! It's been a few weeks since I have been in here. I come asking a new question!
I have noticed that after driving my truck I will 'shake' the rear of the truck and it has a "squeak" (low pitched squeak, like an old trampoline that is rusted out a bit) that I can't place. It sound like it could be coming from the shock, leaf spring, or U-bolt. The interesting thing...It goes away after about 30 seconds of rocking the truck back and forth.
I'm not sure if it's related, but i have also noticed my gas mileage has been lower for a little over a month now too. Then best I have been able to average (all highway, 95% at least) is 16mpg per the overhead console. I even increased my tire pressure to 42 psi as opposed to my normal 38-40 in efforts to help this.
Any ideas or similar stories from any of you?
Old Feb 26, 2010 | 09:37 PM
newmexicoram's Avatar
newmexicoram
Yeah, but it was always the suspension .
Old Feb 26, 2010 | 09:43 PM
dodgetrucker75's Avatar
dodgetrucker75
i wouldnt trust the mpg's on the display, i just made a post a little while back, mine is over 5 mpg's off (low) compared to hand calculations
Old Feb 26, 2010 | 10:22 PM
superdak05's Avatar
superdak05
the squeak could be a sticky brake shoe or pad, have you noticed any type of smell?
Old Feb 27, 2010 | 12:46 AM
bain64's Avatar
bain64
Would the brake shoe make noise when he is just rocking the truck at a stand still?
How many miles on the truck? Have you replaced the shocks?
Old Feb 27, 2010 | 02:26 PM
brbcbrent's Avatar
brbcbrent
I had that same squeak on my dak...started to hear it when I drove over potholes on the one side. Turned out to be the stabilizer links in the rear. Cheap and easy swap out, no more squeaks.
Old Feb 28, 2010 | 01:03 AM
mprohr's Avatar
mprohr
The two are not related. The squeeking is from a bad shock....or shock bushing. Could also be rear sway bar bushings, spring mount bushing, or shackle bushings.
Old Mar 2, 2010 | 02:51 PM
popsnbeer's Avatar
popsnbeer
sorry i left you guys...i moved over the weekend. got my internet back up and running now.
yeah, soon I will have a garage again (once i get the rest of the crap outta there) and be able to look around the shock/bushings/stabilizer links. The rear shocks have about 30-40,000 miles on them, so it's probably time to change them out! I will check the stabilizer first though.
I will hand calculate next fillup! Either way though, since i have been using the overhead display for a year now, and now the MPG's have gone down, I would assume that my hand calculations will have also gone down. I guess we will see where I am at next tank of gas!
