SVC FWD light. What does it mean?
Old Mar 3, 2010 | 11:28 PM
DakotaAgain?'s Avatar
DakotaAgain?
Default SVC FWD light. What does it mean?
Sometimes this light stays on a few seconds longer than other lights(08, V8). Normal? What is it trying to say? I do know this. When in 4WD mode all 4 wheels do NOT lock up. Got stuck a few times and could see only one tire spinning.
Old Mar 4, 2010 | 12:11 AM
rengnath's Avatar
rengnath
Service Four-Wheel Drive. Im guessing if something was triggering the light, the light would stay on or flash constantly and not turn off. Are you under warranty still?
Old Mar 4, 2010 | 05:05 PM
hendrixx324's Avatar
hendrixx324
im pretty sure my light stays on longer than all the others. It gets me when im realy tired but i dont think thats a problem. I have an 06 tho
Old Mar 4, 2010 | 06:11 PM
rengnath's Avatar
rengnath
I looked at it in my 05 this morning. After the engine starts, the light stays on for about 3 seconds and shuts off.
Old Mar 5, 2010 | 08:25 AM
DakotaAgain?
Looks like normal then. But the fact that all 4 wheels do not lock up in 4WD is bothering me. You would not know it unless you are actually looking at them.
Old Mar 5, 2010 | 09:02 AM
sdsdsd's Avatar
sdsdsd
all four do not lock up unless you have LSD differential I believe.
Old Mar 5, 2010 | 10:11 AM
rengnath's Avatar
rengnath
I have the LSD in mine. When I put it in 4wd all four tires spin for a fact. Isnt the point of having 4wd to have all 4 wheels lock? Look in your glove box and it will tell you all the info on your rear differential. It should say the gear ratio and if you have the LSD is should say something like "anti-slip diff"
Old Mar 5, 2010 | 10:43 AM
DakotaAgain?
As far as I am concerned if one wheel is allowed to spin while others just sit there you don't have 4WD. I should not have to order an option to have all wheels lock up. What is puzzling is that I definitely do have 4WD when driving on snow. I can feel the extra grip. Only when I get stuck I see wheels spinning.
Old Mar 5, 2010 | 11:47 AM
whistle pig's Avatar
whistle pig
4 wheel lock is locking the front and rear diffs together for a 50 -50 power split between front and rear. unless you have a limited slip in the rear, you'll never have all four tires spinning at the same time. Open diffs. Power will be transfered from side to side. Front passenger wheel spins, rear driver spins, and so on. Get ARB air lockers then you'll see a rear "4x4"
Old Mar 5, 2010 | 02:43 PM
rengnath's Avatar
rengnath
Thanks for the info whistle pig, I never knew that. Its kind of a rip off for 4wd without a limited slip diff then IMO.
Did you confirm what diff you have Dakotaagain?
