strange noise
Old Mar 5, 2010 | 05:17 PM
paul05dak's Avatar
paul05dak
Default strange noise
Ok in my 05 Dakota quad, I am getting a strange rattle or vibration but not all the time. After it warms up and I'm doing anywhere between 30 - 40 it happens. I am coasting between those speeds and lightly give it gas, it has what I would call a sweet spot where the rattling happens. Also it happens in reverse. I open the window to listen and don't hear anything. Sounds like it is coming from unfer the read driver side seat. I gace it a quick look but can't find anything. Pumpkin has no signs of leaking (although I know that doesn't mean much) and there is nothing in the back bed. at first I thought it was my gas door as it was lose and would rattle when I push against it. hopeing that is it. Back tailgate seams tight, roll n lock could be getting lose, checked where it connects to the tail gate and thee were lose screws. tightened them up also. Sorry for rambling but just wondering if anyone else had someting like this. Don't hear it all the time and exceleration is still as normal. No slipping when I gun it.. confused on what to look for next.
Old Mar 5, 2010 | 07:39 PM
Blown287's Avatar
Blown287
Mine did something like that when I first installed the alcohol pump in the back. Check the sheet metal insert that closes off the bed of the truck from the cab. It just kind of slides in there.
Old Mar 7, 2010 | 03:20 PM
paul05dak's Avatar
paul05dak
ok I have good news and bad news... Good news is i think I found the issue. bad news is I have to bring it back to monroe. too bad the person I really wanted to work on it was transfered (Rare, I miss you in CP!!) Seams that once it warms up, there is enough movement that when I hit a certin RPM, it vibrates enough to hit the under carrage. SOO back to monroe for a 3rd time tomorrow to have them readjust it. I was able to get under today and figure out where the sound is coming from. This is also after I put it back into stock mode (have the superchips programmer) At least its a piece of mind knowing it isn't something drastic!
Old Mar 7, 2010 | 05:03 PM
Altair's Avatar
Altair
Dak attack!
I assume you mean exhaust? You never actually told us what it was that's moving.
Old Mar 7, 2010 | 07:19 PM
paul05dak's Avatar
paul05dak
oops yes the exhaust... My bad.
