BACK from Middle East with pics~
Old Mar 24, 2010 | 02:00 PM
  #52
trucky's Avatar
trucky
Thanks Josh
Eric- It wasn't in the picture but I have the relay. Did your bulbs fit in the headlight housing or did you have to drill/glue it on? It definitely does not fit in like stock.
Old Mar 24, 2010 | 02:16 PM
  #54
trucky's Avatar
trucky
h13, bi-xenon.
Old Mar 24, 2010 | 04:44 PM
  #56
trucky's Avatar
trucky
So I suck at life and couldn't figure out the HID kit without a vehicle specific diagram, and my VLED turn signals need 6 ohm load resistors so those are not in yet, so here is just the clear corner black headlights installed. I also got my clutch fan off and I doubt THAT was the easiest part because it took 60 seconds, heh.
Old Mar 24, 2010 | 08:27 PM
  #57
Blown287's Avatar
Blown287
Originally Posted by trucky
I'm scared to tackle the E-fan...
Bring it over Saturday, I will help you with it.
Old Mar 25, 2010 | 12:37 AM
  #59
biker_ahoy's Avatar
biker_ahoy
Mine also get the flicker, but only if the lights switch is in the off position and the truck is in gear, this is fixed once the headlight are turned all the way on. mine have the relays, and plug into one of my headlight stock plugs, oh and the main relay that plugs into the truck buzz's like it's not getting enough current from the truck when the light switch is in the off position.
I don't know what to make of it, other than the fact that the daytime running lights are the Highbeams at a lower current.
Old Mar 25, 2010 | 02:37 AM
  #60
Slick Dakota's Avatar
Slick Dakota
Looks good trucky, I am looking at the headlights and wondering when I buy mine that I may spray paint that silver edge around the out side black, just to make it blend in some.. The thing is your truck is silver and that silver trim is not bad but for my truck being red then having that silver edge then to black may not look right..
I also see you painted your grill good deal, i myself was going to go black as well but guys at work told me I should paint it to match the body color and they pretty much have me convinced of it, thanks for keeping us updated..
I say still say put one wheel on your truck "front" crank the wheel and see what it hits.. no hurt in trying it's not like your going to be driving around or anything,, Cya Slick
