Thump thump noise from rear end
Old Mar 23, 2010 | 08:11 PM
05Dakotaho's Avatar
05Dakotaho
Default Thump thump noise from rear end
At slow speed such as backing out of garage or rolling over a small bump at under 5mph I hear a thump thump. It's like a muffled clunk clunk.
Have new shocks and bushings. New axle bearings and differential innerds.
Could be:
Body to frame mounts.
Spring shackles or bushings.
Tail gate
Any ideas?
05 Dakota Crew 4x4 with under 50,000 miles
Old Mar 23, 2010 | 10:21 PM
hendrixx324's Avatar
hendrixx324
Does it kind of sound like somthing can be loose?
Old Mar 24, 2010 | 06:20 AM
05Dakotaho's Avatar
05Dakotaho
Yes it does.
Old Mar 24, 2010 | 01:52 PM
blakdak07's Avatar
blakdak07
Spare tire, exhaust?
Old Mar 24, 2010 | 05:52 PM
Eimer123's Avatar
Eimer123
I would check to make sure your new shocks are bolted tight.
Old Mar 24, 2010 | 08:58 PM
ReturnToSender's Avatar
ReturnToSender
Sway bar links?
Old Mar 24, 2010 | 10:44 PM
hendrixx324
Mine does the same thing... i think its the spare tire... i havent found the cause yet though.
Old Mar 25, 2010 | 06:05 PM
DON'TCARE05's Avatar
DON'TCARE05
i bet if you look under at where the shock mounts to the truck you will see that the new shock is smaller then the stock one. meaning the the mounting bracket needs to be clamped in a little to stop the movement of the shock in the bracket. you can have the bolt tight on the top but the shock top will still move back and forth in the mount. took me about a day to figure mine out after changing.
Old Mar 25, 2010 | 06:07 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
u-joint?
Old Mar 26, 2010 | 11:10 AM
superdak05's Avatar
superdak05
check your tires. i had the same issue, and there was a piece of dried tar stuck between the threads
