okay im really mad guys help?
Old Mar 27, 2010 | 11:53 PM
Moneyman19's Avatar
Moneyman19
do they make aftermarket ones that are better? if so dealership will do that if i request or push them to do it. mine is on the left side (drivers side) its the first one if u were standing infront of the engine.
Old Mar 28, 2010 | 12:04 AM
hendrixx324's Avatar
hendrixx324
If your not looking for Speed and lots of power, Those 4.7 Rams have plenty of power to get the job done, My dad has one, He loves it, I love it. Its so nice to drive around
Old Mar 28, 2010 | 11:28 PM
Moneyman19's Avatar
Moneyman19
well this morning it was 23 degrees out (5:30am) truck started fine no tap.... drove it a good amount today on and off working security and going trough mud grrr to stop ppl because it was sumbodys SOD farm and they were tearing up the SOD... mostly the new york ppl and then getting stuck in the mudd made sum money so far so good im just listing to it everytime i start it. in 3,000 miles oil getting changed again anyways so by then there wont be whats left of the thicker oil..
Old Mar 28, 2010 | 11:51 PM
Altair's Avatar
Altair
Dak attack!
You get a 4.7 Ram and you still have the same engine you have right now. Don't bother with the Lucas, I've never used it and always had good oil test results.
Get a decent synthetic, Mobil 1 at least or Amsoil/Royal Purple, 5w-30 or 5w-20 depending what it calls for in your manual and on the oil cap and change the filter too. I would recommend always changing the filter when changing the oil, if you are tighter on cash go to Napa and get the Napa Gold oil filter for your truck. They are actually made by Wix and are a high quality filter.
If after doing that the truck still ticks when warm (not just when warming up) take it to the dealership or a good mechanic and explain what has been done and that you suspect the valve lash adjustors. Lemon law requires that the truck be taken in for the same issue 3 times and not be fixed, it doesn't sound like yours is a lemon, seems like she just wants some attention and the right weight oil.
Old Mar 29, 2010 | 12:03 AM
Moneyman19's Avatar
Moneyman19
i always change the oil filter when i change the oil i use K/N 2004. reason i was told to leave the oil filter in on this one was ebcause it had less then 200 miles on it. it been to the dealership 5 times just on a problem (not this one) so ive already qualified for it. shes running good now just still trying to firgure out this jerkiness when hes doing the brakes going to ask him to blow the injectors again. thanks all for the help. did note if it starts happing again dealership gonna do solid vavle lashes
Old Mar 29, 2010 | 06:22 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I am not a fan of additives either...
Old Mar 29, 2010 | 06:40 PM
lghtngblt02
Originally Posted by ericemery
I have ran lucas in a few vehicles. but never with a full syn.
I have some in the talon right now, hoping to sort out where a leak is.
Thats different... I am saying to make it "better", I dont believe in them!
Old Mar 29, 2010 | 07:55 PM
Altair's Avatar
Altair
Dak attack!
Well they may help with regular oil but there is no use for them with a high quality synthetic, and since I'm a full believer in synthetics (started on Mobil 1 and moved on to Amsoil) I have no use for the additives.
