efan not working
Old 03-30-2010 | 05:03 PM
lmrjason's Avatar
lmrjason
Default efan not working
can't get my fan to cut on, error code says fan not found. it worked this morning. i'm too pissed to troubleshoot everything right now.
Old 03-30-2010 | 07:53 PM
lmrjason's Avatar
lmrjason
checked all the connections and fuses...everything was hooked up right. cut the power and ground wires from the fan and hooked them up directly to the battery and it kicked right on...it has to be the controller. I took the fan and controller out and put the clutch fan back in for now. going to try and contact spal and see what they say.
Old 03-30-2010 | 08:03 PM
lmrjason's Avatar
lmrjason
i just emailed them. hopefully they won't give me that crap saying they can't help me since i didn't hook it up to one of there fans.
Old 03-31-2010 | 05:59 PM
studlyblueiz's Avatar
studlyblueiz
I doubt it. The Spal controller has held up to my demanding taurus fan with no problems so I wouldn't suspect your fan to have caused it. Could it be your temp sensor? If the unit is getting power I'd check that or make sure another one of your unused wires isn't grounding.
Old 03-31-2010 | 06:00 PM
lmrjason's Avatar
lmrjason
Got it halfway working...guy from spal told me how to disable the diagnostics on the spal controller. It cuts on with the ignition now so it is always on...better than not working at all. going to email him tomorrow and see if i can just reprogram the unit to factory settings.
Trending Topics
Old 03-31-2010 | 06:55 PM
Blown287's Avatar
Blown287
I heard that. IMHO SPAL is the best controller out there. Direct plug n play with both low and high settings. I hope you get it back to 100%
Old 03-31-2010 | 08:20 PM
lmrjason's Avatar
lmrjason
I just emailed him again. prolly won't get a response til tomorrow
Quick Reply: efan not working
