Over heating!!!
Old Apr 5, 2010 | 10:10 PM
hendrixx324's Avatar
hendrixx324
Oh well i can here my clutch fan spinning when i start it up iun the mornjing and drive away
Old Apr 6, 2010 | 12:51 AM
Blown287's Avatar
Blown287
Originally Posted by Eimer123
You can also warm some water up on the stove to about 200 degrees (use a thermometer) and see if it opens.
Yes Sir, that is how I was trouble shooting Trucky's thermostat on his fan controller.
Old Apr 6, 2010 | 12:56 AM
canadian dakota's Avatar
canadian dakota
wait wait wait what i dont fallow this water therory
Old Apr 6, 2010 | 10:45 AM
superdak05's Avatar
superdak05
take out the stat and put it in a boiling pot of water on the stove, you will see the stat open up right before your eyes. also the newer stats are fail safe, when they fail, they go into the open mode, thus not over heating the engine and causing damage, another thing to check on the radiator, run the truck upto temp, check the bottom rad hose and see if it is hot, if it is, than the system is circulating
Old Apr 6, 2010 | 11:11 AM
hendrixx324
Originally Posted by ericemery
You havent ever used any sort of radiator stop leak have you?
nope.
Old Apr 6, 2010 | 01:32 PM
canadian dakota
interesting never knew that like I said mine only does it when the ac was on and only a couple time ill have to keep an eye on it this summer
Old Apr 6, 2010 | 01:57 PM
Dinger838's Avatar
Dinger838
yepp we use that on boats to at work. pretty cool to watch it work
